fuel injection fuel pump, overflow |
jimkelly |
Jul 18 2005, 08:50 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I am thinking of using a MSD-2225 fuel pump with a 2.0 that is gonna replace my 1.7. But it does not have a return valve or overflow valve. Is this a problem? Jim
Jake Raby |
Jul 18 2005, 08:53 AM
Jim, I got your email but decided to answer here..
I used the MSD pump in my 912E and it failed in 2,000 miles- got loud and quit. I used one on the dyno 4 weeks ago and it did the same thing. Stick with Mallory for fuel pumps. Their 4060 FI is what I have made standard in my FI kits. |
jimkelly |
Jul 18 2005, 09:33 AM
Jake,
Excellent! Question - description says - All Comp Pump series fuel pumps must be used with a fuel pressure regulator. What regulator should I use with a stock 2.0L? Thanks, Jim http://store.summitracing.com/default.asp?...h.asp&x=32&y=13 |
Jake Raby |
Jul 18 2005, 09:48 AM
I have used the stock pressure regulator with this pump- the 912 is running the stocker- works like a charm.
jimkelly |
Jul 18 2005, 10:04 AM
Jake,
Thanks again. Fuel pump $150 and fuel press reg $100. Not 100% sure I'll need to buy a fuel pump - but it is very good to know which one to buy if I do and that I can use my stock press regulator! Jim |
Lo-Fi Version | Time is now: 14th May 2024 - 09:25 AM |
