jimkelly
Jul 18 2005, 08:50 AM
I am thinking of using a MSD-2225 fuel pump with a 2.0 that is gonna replace my 1.7. But it does not have a return valve or overflow valve. Is this a problem? Jim
Jake Raby
Jul 18 2005, 08:53 AM
Jim, I got your email but decided to answer here..
I used the MSD pump in my 912E and it failed in 2,000 miles- got loud and quit.
I used one on the dyno 4 weeks ago and it did the same thing.
Stick with Mallory for fuel pumps. Their 4060 FI is what I have made standard in my FI kits.
jimkelly
Jul 18 2005, 09:33 AM
Jake,
Excellent!
Question - description says - All Comp Pump series fuel pumps must be used with a fuel pressure regulator.
What regulator should I use with a stock 2.0L?
Thanks,
Jim
http://store.summitracing.com/default.asp?...h.asp&x=32&y=13
Jake Raby
Jul 18 2005, 09:48 AM
I have used the stock pressure regulator with this pump- the 912 is running the stocker- works like a charm.
jimkelly
Jul 18 2005, 10:04 AM
Jake,
Thanks again.
Fuel pump $150 and fuel press reg $100.
Not 100% sure I'll need to buy a fuel pump - but it is very good to know which one to buy if I do and that I can use my stock press regulator!
Jim
