Washer hose spare tire fitting |
bbrock |
Feb 8 2021, 07:40 PM
I know this is a futile quest since most of you think it is only civilized to convert the pneumatic windshield washer to an electric pump. But c'mon, that has to be the most ridiculously quirky quirk of a car dripping with quirkiness. Anything that stupid has to be worth keeping... right?
But I have a problem. The seal inside the fitting that screws onto the spare tire was shot and leaking all the air out of the tire. That wasn't going to work so I dug it out and and replaced it with a stack of neoprene washers that looked to be the right size and sealed to each other with a smear of RTV. It worked... almost. It seals tight unless you bend the hose to the side at all and then it leaks. Of course, mounting the tire in the frunk with the hose on bends it to the side. So what to do? Anyone have suggestions on how to seal this thing, or where a replacement might be found? New hoses with fittings are NLA and the ransom demanded by folks with used ones seems steep considering they might very well leak also. Thoughts? (IMG:style_emoticons/default/confused24.gif) |
wonkipop |
Feb 9 2021, 09:22 AM
Advanced Member Group: Members Posts: 4,264 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
i have found this - i might chase up myself.
from M & T manufacturing. VW restoration parts. its a new part they make themselves that is close to the original part. but is the whole thing cap, hose and tyre fitting. https://www.mtmfg.com/part/view/window-wash...rt=311-955-979B |
DRPHIL914 |
Feb 9 2021, 10:06 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i have found this - i might chase up myself. from M & T manufacturing. VW restoration parts. its a new part they make themselves that is close to the original part. but is the whole thing cap, hose and tyre fitting. https://www.mtmfg.com/part/view/window-wash...rt=311-955-979B interesting find! well i have the electric pump oem 911 from 914sixer, and put in the converted switch in the column , from Carmagic, and now the lever when pulled will push the switch and trigger the pump, that is not installed yet, but hope to soon, no more water inthe lap out of the steering column for me! |
Lo-Fi Version | Time is now: 5th May 2024 - 07:47 AM |
