Washer hose spare tire fitting |
bbrock |
Feb 8 2021, 07:40 PM
I know this is a futile quest since most of you think it is only civilized to convert the pneumatic windshield washer to an electric pump. But c'mon, that has to be the most ridiculously quirky quirk of a car dripping with quirkiness. Anything that stupid has to be worth keeping... right?
But I have a problem. The seal inside the fitting that screws onto the spare tire was shot and leaking all the air out of the tire. That wasn't going to work so I dug it out and and replaced it with a stack of neoprene washers that looked to be the right size and sealed to each other with a smear of RTV. It worked... almost. It seals tight unless you bend the hose to the side at all and then it leaks. Of course, mounting the tire in the frunk with the hose on bends it to the side. So what to do? Anyone have suggestions on how to seal this thing, or where a replacement might be found? New hoses with fittings are NLA and the ransom demanded by folks with used ones seems steep considering they might very well leak also. Thoughts? (IMG:style_emoticons/default/confused24.gif) |
Superhawk996 |
Feb 10 2021, 02:41 PM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I admire the perseverance . . . (IMG:style_emoticons/default/screwy.gif)
(IMG:style_emoticons/default/happy11.gif) |
bbrock |
Feb 24 2021, 11:31 AM
I admire the perseverance . . . (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/bs.gif) "admire" my (IMG:style_emoticons/default/bootyshake.gif) But I think I solved the problem. I plugged in the metal schrader fitting from Amazon 2 days ago and inflated the tire to 42 psi. Holding rock steady so far. No leaks (IMG:style_emoticons/default/cheer.gif) Next step is to hook up the bottle to pressurize the rest of the system to make sure there are no other leaks. |
Lo-Fi Version | Time is now: 5th May 2024 - 11:13 AM |
