GB Wheel center caps $99 Polished like OEM caps for Fuchs Predrinis, and MahleS, 10 sets $99 a set of 4. * 1set Left of the 10 |
Rods914 |
Feb 21 2021, 09:15 PM
Rods914 Group: Members Posts: 18 Joined: 24-June 03 From: Peoria, Ill 61615 Member No.: 853 Region Association: Upper MidWest |
If someone drops out I would like a set.
Mikey914 |
Feb 22 2021, 03:55 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Mark @Mikey914 , Thank you for doing this. i did order mine and the code that you sent to me did not work so i pm'd you and got no response then i called a couple times to the shop and only got voicemail. i left a message regarding the situation but no call or credit back for the difference. Not a fan of having to chase around something like this. Chris The code was o ly for the polished center caps that were in the link provided in the PM. Looks like you wanted the satin. They are less expensive but can do for the same price if you want. Just let me know. Mark |
Lo-Fi Version | Time is now: 9th June 2024 - 07:45 AM |
