FS: complete D-Jet for 1.7 |
r3dplanet |
Feb 18 2021, 11:58 AM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
Hey gang.
I've sold my 914 and now I'm selling the remainders. First up: my complete 1.7 liter D-jet system. Each part has been individually tested but it has never been tested as a complete system on a running engine. That's because unknown to me my original '73 engine had been rebuilt with a mish-mash of parts meant for a carbureted engine. Includes rebuilt MPS and new wiring harness. Also has the ECU. Does NOT include the correct injectors - it has the 1.6 liter VW black injectors so you'll need to source correct injectors depending on your application. Notable absent is the cylinder heat temp sensor because it went with the car. But you can get one here: https://914rubber.com/cylinder-head-temperature-sensor-1 Also, the intake tubes are painted signal orange. I hope you like orange as much as I do. Kit includes some extra bits that may or may not work and a part that I think actually belongs to a 2.0 liter D-Jet setup. $750. -marcus |
bdstone914 |
Feb 18 2021, 12:26 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hey gang. I've sold my 914 and now I'm selling the remainders. First up: my complete 1.7 liter D-jet system. Each part has been individually tested but it has never been tested as a complete system on a running engine. That's because unknown to me my original '73 engine had been rebuilt with a mish-mash of parts meant for a carbureted engine. Includes rebuilt MPS and new wiring harness. Also has the ECU. Does NOT include the correct injectors - it has the 1.6 liter VW black injectors so you'll need to source correct injectors depending on your application. I'm in Portland, Oregon. I'm not currently mobile so it would be better if someone vaguely local came and grabbed it. But I might be able to find a helper to get it boxed and shipped. It's fairly heavy altogether. Also, the intake tubes are painted signal orange. I hope you like orange as much as I do. @hotshoe Asking $750. -marcus |
bdstone914 |
Feb 20 2021, 10:09 AM
Hey gang. I've sold my 914 and now I'm selling the remainders. First up: my complete 1.7 liter D-jet system. Each part has been individually tested but it has never been tested as a complete system on a running engine. That's because unknown to me my original '73 engine had been rebuilt with a mish-mash of parts meant for a carbureted engine. Includes rebuilt MPS and new wiring harness. Also has the ECU. Does NOT include the correct injectors - it has the 1.6 liter VW black injectors so you'll need to source correct injectors depending on your application. I'm in Portland, Oregon. I'm not currently mobile so it would be better if someone vaguely local came and grabbed it. But I might be able to find a helper to get it boxed and shipped. It's fairly heavy altogether. Also, the intake tubes are painted signal orange. I hope you like orange as much as I do. Asking $750. -marcus @r3dplanet I know a possible buyer. Does it include the distributor, fuel pump ? Is the air filter the oil bath or paper element type? A picture would be helpful. |
r3dplanet |
Feb 23 2021, 06:14 PM
r3dplanet |
Feb 23 2021, 06:16 PM
r3dplanet |
Feb 23 2021, 06:19 PM
r3dplanet |
Feb 23 2021, 06:26 PM
New air breather tube from Mark at 914rubber:
And then various extra bits including a vacuum gadget, extra air valve that may or not work, a new electric fuel pump, deceleration valve, etc. All of the other sensors are mounted on the plenum already. MPS valve, correct part number, holds vacuum, rebuilt with kit from Chris Foley, and adjusted accordingly. |
r3dplanet |
Feb 23 2021, 06:31 PM
r3dplanet |
Mar 10 2021, 09:10 PM
bump
r3dplanet |
Apr 1 2021, 06:22 PM
bump-a-lump
r3dplanet |
Apr 26 2021, 11:10 PM
*bump*
Lo-Fi Version | Time is now: 18th May 2024 - 07:17 PM |
