What front offset for Fuchs on 914/6 narrow body? |
maj75 |
Feb 19 2021, 07:19 AM
Member Group: Members Posts: 69 Joined: 26-May 20 From: Lighthouse Point, FL Member No.: 24,317 Region Association: None |
My 914-6 conversion will have ‘79 911 Bilstein struts, ‘79 911 hubs and ‘84-89 911 calipers and rotors. I’m keeping the narrow body and want to run 15x7 Fuchs. I see a couple of offsets advertised. I need to get the wheels before I get the front suspension assembled so I can continue to move the car around and not tie up the lift.
I have the new struts and hubs, but not the brake components. If you see an issue there, let me know. |
SavingManuals |
Feb 19 2021, 07:53 AM
Member Group: Members Posts: 100 Joined: 5-January 21 From: Metro Detroit Member No.: 25,044 Region Association: None |
mepstein |
Feb 19 2021, 08:08 AM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Attached thumbnail(s) Attached image(s) |
Racer |
Feb 19 2021, 11:21 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
My 914-6 conversion will have ‘79 911 Bilstein struts, ‘79 911 hubs and ‘84-89 911 calipers and rotors. I’m keeping the narrow body and want to run 15x7 Fuchs. I see a couple of offsets advertised. I need to get the wheels before I get the front suspension assembled so I can continue to move the car around and not tie up the lift. I have the new struts and hubs, but not the brake components. If you see an issue there, let me know. While you can fit a 7x15 up front (it will rub the inside fender well) the larger issue is getting the 7x15 to fit in the back. The rear fenders are tighter. Some get them to fit with no issues.. others need to "massage" quite a bit. Your car is "early" offset.. so, a 7x15, et (offset) 23 would fit. "late" offset is 1987 944 and newer. They have et's in the 45-60 range. All fitment larger than a 6x15, et36 will come down to items like: 1) Ride height 2) Alignment 3) stiffness (spring/torsion bar rate) 4) tire size 5) "massaging" - rolling lips to pulling the fenders to adding flares. |
maj75 |
Feb 19 2021, 01:19 PM
Thanks for the fast responses.
I don’t mind rolling the fenders, but definitely don’t want flares. If 15x6 is “safe” is there any compelling reason to go with 7” width. Wasn’t thinking wider than 205. Would the wheel width make that much of a difference? |
scallyk9 |
Feb 19 2021, 01:31 PM
Member Group: Members Posts: 321 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
Thanks for the fast responses. I don’t mind rolling the fenders, but definitely don’t want flares. If 15x6 is “safe” is there any compelling reason to go with 7” width. Wasn’t thinking wider than 205. Would the wheel width make that much of a difference? I have 205/60/15s on both of my narrow-bodied 914s with no rubbing except perhaps for some minor rubbing on the front inner fender well at full steering lock. Fenders are not rolled or modified. Wheels are 15x6 Mahles on the LE and 15x6 5 lug Fuchs on the 3.2L conversion. I've purchased a set of 16x6 Fuchs with the same 36mm offset for the 3.2L and they currently have 205/50/16s mounted. |
scallyk9 |
Feb 19 2021, 01:44 PM
mepstein |
Feb 19 2021, 01:54 PM
205x60x15 on 6x15 Fuchs fit great on 99% of 914’s. 7’s can give you issues, especially in back.
Racer |
Feb 19 2021, 01:56 PM
Thanks for the fast responses. I don’t mind rolling the fenders, but definitely don’t want flares. If 15x6 is “safe” is there any compelling reason to go with 7” width. Wasn’t thinking wider than 205. Would the wheel width make that much of a difference? Mostly aesthetics as folks seem to like the "deeper dish" of the wider wheel. Even with a 7, most can't fit more than a 205 tire without "massaging" the fenders. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:49 AM |
