Front Oil Cooler w/Fan Pictures Needed, Thank you! |
xitspd |
Jul 18 2005, 03:41 PM
Technology and Tradition 3.6 and 914-6 Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 |
I have a B&B front mounted oil cooler installed in my 914-6 with a 3.6 964 based engine. I am ducting the air through the two factory ports in the front truck floor. I am having carbon fiber ducting made to force the air from the front air dam opening into the two factory ports. I need a picture or pictures of electric fans mounted in the front trunk. I will use the fans during warm days when the car is not moving. I appreciate your help!
Brad Roberts |
Jul 18 2005, 05:32 PM
Dan,
I want to help, but I dont know what the B+B cooler looks like. Show me what you have and I'll show you some coolers/fans I doubt seriously you need fans on the cooler. I know our RSR replica and the factpry RSR here at the shop has twin 993 coolers with no fans. B |
brant |
Jul 18 2005, 05:45 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Dan,
also won't the fans be a restriction to the car when it is moving.... so as a dedicated track car which never sits still at stop lights.... you may not want the fans. I know the 3.6 is an entirely different beast than our car and that we still have the factory cooler with fans already... but we are so over cooled, I would think that you could easily get away with no fans for staging and short sits. Attached image(s) |
Brad Roberts |
Jul 18 2005, 06:10 PM
Here is the passenger side oil cooler. No fans. The bumper is built so it directs the cooling air between the body and into the cooler. The exit is just in front of the tire.
B |
Brad Roberts |
Jul 18 2005, 06:12 PM
This is the passenger side.
Roger Sheridan runs two of these in a V-shape with a common air entrance and dual exits. Pretend the V opens towards the front of the car. NO fans. B |
Brad Roberts |
Jul 18 2005, 06:14 PM
Brants 914 is done the same way all of the Gunnar cars are built. Very efficient and tidy.
B |
siverson |
Jul 18 2005, 07:00 PM
Advanced Member Group: Benefactors Posts: 2,448 Joined: 5-May 03 From: San Diego, CA Member No.: 654 Region Association: Southern California |
I need fans on mine as well and am planning on adding them. Fine if the car is moving, but not (a) waiting in line at the track, or ((IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) traffic, or © the TJ border crossing (not the place you want to overheat!).
-Steve |
Brad Roberts |
Jul 18 2005, 07:15 PM
I agree 100% all the street cars with 3.6's should have a fan on the stock style oil cooler.
brant |
Jul 18 2005, 08:16 PM
I had to get the idea somewhere.... no room with the oversized cell otherwise. ha... brant |
RON S. |
Jul 19 2005, 05:08 AM
9140430841, FINALLY RUNNING Group: Members Posts: 1,211 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
I put these 3 fans on my unit.These fans flow 100cfm a piece,and are mounted to the back of the Mazda oil cooler with a simple bolt on frame I designed on cad,and lasered out.
They can be disconnected and removed with a couple of Allen wrenches in about 15mins. if needed. My car has a 993 motor,and will eventually be primarily street driven,so I felt i'd need extra cooling,for the stop & go traffic. I know that the car is not on the road yet,but so far this summer with the car idling for a good solid hour in 95 deg.heat w/high humidity the temp gauge has only climbed as high as 205-210 deg.w/the fans running at full tilt.You can definately feel the airflow thru the front grill. I know that idling isn't putting a load on the engine yet,but it isn't overheating either. Ron Attached image(s) |
xitspd |
Jul 19 2005, 07:53 AM
Thanks guys! I will take a picture of the oil cooler mounted in the car when I can get a chance and post it. I look forward to your comments. Thanks again.
xitspd |
Jul 24 2005, 12:12 PM
Brad,
Attached please find a picture of my B&B front mounted oil cooler. Do you think it is large enough that a fan will not be needed for my 3.6? Dan (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) Attached image(s) |
xitspd |
Front opening...
xitspd |
Jul 24 2005, 12:14 PM
The openings that the ducting will dump air into....
brant |
Jul 24 2005, 12:32 PM
don't take this as judgemental... but I played around with 3 different exits on the cooler in my old car. I took actual oil temps and found that each time I increased the exit volume, I also dropped my oil temps. I think optimum is to have the exit about 50% bigger than the intake hole.. (unless you can get a venturi or draft effect to help out)
based on that, you may want to increase your exit size if you need addtional temp efficiency. brant |
xitspd |
Jul 24 2005, 12:46 PM
Thanks, Before the 3.6 installation I ran a 2.0 906 spec engine in the car with a Mazda front mounted cooler. I raced the car for 5 years and it handled the oil temp OK. The 906 motor had a factory cooler on the engine in addition to the front mounted Mazda cooler, the 3.6 has no provision for a factory mounted oil cooler. The B&B cooler is huge, but is it enough and is a fan system needed? I agree with you about opening up the front truck floor for additional air flow. The carbon fiber ducting fabricator suggested the same. |
xitspd |
Jul 24 2005, 10:07 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) Paging Brad! Fan needed or not? More holes needed or not? Thanks...
Dan |
Aaron Cox |
Jul 24 2005, 10:18 PM
BTW - where do your lines go before they make it to the rocker panel?
xitspd |
Jul 24 2005, 10:28 PM
The lines exit the cooler and move to the top of the inside passenger front fender flare, then down and along the rocker panel. |
pete-stevers |
Jul 24 2005, 10:38 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
What make and model cooler are you running?
what dealer did you purchase it from? I am looking for a cooler as we speak steve |
Lo-Fi Version | Time is now: 29th April 2024 - 03:45 PM |
