Repairing Engine Tin, A newbie's lesson in welding - second side |
seanpaulmc |
Feb 22 2021, 07:20 PM
Member Group: Members Posts: 297 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
I recommend all new welders to get some 50 year old thin gage sheet metal to learn with. (IMG:style_emoticons/default/welder.gif) How hard could it be?
In doing so, you’ll practice with voltage and wire speed, stick out, part set up, metal cleaning, contamination and porosity, work area lighting, youtube, weld grinding, fabrication, clamping, gapping, blow thru, backing materials, warping, patience and wire brushing, to name a few. What I have... How many cracks can you spot? Save your original OG engine tin they say. It's the best they say. So after a few hours... I'm not kidding anyone here with these pictures, after many days I find myself with this... I have several questions for those with at least a few hours more experience. 1) How much more, if any, should these welds be ground down? Or, will the weld beads provide future strength to the thin, stretched sheet metal so leave as-is? 2) In order of preference, what would be the best three tools to use to grind down welds on thin sheet metal? Assume you don't have an air compressor. I don't. 3) For the top section where the coil attaches on the tin, the coil bracket uses P/N: N 010 210 13 which is M 6 x 10 hex-head bolt. Is the tin supposed to have a captured nut on the backside or just thicker sheet metal in the locations that are missing on my tin (see first few pictures). 4) Should the coil mounting location be relocated in order to avoid whatever the hell happened here? If so, where? In actuality I'm quite please with the results so far, maybe not the pace of the work, but at least the product thus far. It'll be useable tin and certainly better than it was. (IMG:style_emoticons/default/screwy.gif) This is literally the first time I have ever fabricated a patch and tried to weld anything. I'm working my way up to the easy stuff if there such a thing? I appreciate you entertaining my questions. Thanks, Sean |
wonkipop |
Apr 9 2021, 04:09 AM
Advanced Member Group: Members Posts: 4,264 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
mate
you are a hero for working out how to do this. fortunately i do not own one with a coil screwed down on the tins. which german kook thought that was a good idea? and those guys are the masters of metal? (you know the germans have some kind of perverse respect for the brits?) the japs would never have made that mistake. thousands of years making swords. but good old american know how to sort it. (mind you same know how also screwed the cars, but would be the same here). (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 4th May 2024 - 07:48 PM |
