Repairing Engine Tin, A newbie's lesson in welding - second side |
seanpaulmc |
Feb 22 2021, 07:20 PM
Member Group: Members Posts: 297 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
I recommend all new welders to get some 50 year old thin gage sheet metal to learn with. (IMG:style_emoticons/default/welder.gif) How hard could it be?
In doing so, you’ll practice with voltage and wire speed, stick out, part set up, metal cleaning, contamination and porosity, work area lighting, youtube, weld grinding, fabrication, clamping, gapping, blow thru, backing materials, warping, patience and wire brushing, to name a few. What I have... How many cracks can you spot? Save your original OG engine tin they say. It's the best they say. So after a few hours... I'm not kidding anyone here with these pictures, after many days I find myself with this... I have several questions for those with at least a few hours more experience. 1) How much more, if any, should these welds be ground down? Or, will the weld beads provide future strength to the thin, stretched sheet metal so leave as-is? 2) In order of preference, what would be the best three tools to use to grind down welds on thin sheet metal? Assume you don't have an air compressor. I don't. 3) For the top section where the coil attaches on the tin, the coil bracket uses P/N: N 010 210 13 which is M 6 x 10 hex-head bolt. Is the tin supposed to have a captured nut on the backside or just thicker sheet metal in the locations that are missing on my tin (see first few pictures). 4) Should the coil mounting location be relocated in order to avoid whatever the hell happened here? If so, where? In actuality I'm quite please with the results so far, maybe not the pace of the work, but at least the product thus far. It'll be useable tin and certainly better than it was. (IMG:style_emoticons/default/screwy.gif) This is literally the first time I have ever fabricated a patch and tried to weld anything. I'm working my way up to the easy stuff if there such a thing? I appreciate you entertaining my questions. Thanks, Sean |
seanpaulmc |
Apr 19 2021, 06:51 AM
When taking the Tin off the engine, I have this small piece on the 3/4 side at the back part of the head. The leading part of the head is where the oil cooler is. Not a very good picture.
I think this is part 20 in the PET - 022 119 361, air duct /H/R. Of course this part is missing on the left side of my engine. I think I need part 21 in the diagram which for the 2.0L is 039 119 362, air duct /H/L. Would someone confirm the P/N for me? WTB this part if anyone has extras? Thanks |
Lo-Fi Version | Time is now: 27th April 2024 - 03:43 AM |
