Gear Shift knob |
Gear Shift knob |
stickyfingers |
Feb 25 2021, 11:45 AM
Member Group: Members Posts: 168 Joined: 19-February 21 From: Toronto Member No.: 25,223 Region Association: Canada |
Hi all. First of all I love this forum. I'm really appreciating all the help everyone has been giving. This community is top notch and without judgement.
I'm finding all these small challenges with the vehicle but working through them one by one. This question is related to the shifter knob. Mine comes right off while driving - kind of annoying and dangerous at times. Seems like the previous owner put in two sided tape in the inside of the knob to kind of keep it in place. I have checked the screw attached to #2 in the attachment below just moves around - not really thread it in there. I removed the screw but cannot seem to remove the #2 piece - don't know what we call that. Sorry for being such a noob. Question 1: is there a way to remove that? Question 2: should I just put some gorilla glue in the knob to hold it in place (lol). Question 3: Should I buy a replacement (I love the existing knob) - see pics. Searched previous posts and saw that people are suggesting I put a towel and slightly hammer a wrench upwards to remove that bushing (held by the non-working allen screw). But not sure if it will solve the issue. So just looking for your guidance on what is the recommend option. Again, any help would be greatly appreciated. Thank you! |
rjames |
Feb 25 2021, 11:55 AM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Try a new crush washer
https://914rubber.com/shifter-crush-sleeve If that doesn't work, use something to shim around the washer so it's a tighter fit. |
stickyfingers |
Feb 25 2021, 11:56 AM
Thanks rjames. I believe the crush washer is already there no? isn't that what my current knob goes on?
Mark Henry |
Feb 25 2021, 12:04 PM
The crush washer is a one time use only, get a new one.
stickyfingers |
Feb 25 2021, 12:07 PM
ah ok. How is it connected to the knob (the knob just slides on to it) wouldn't the knob still slide out even with the new crush washer?
bbrock |
Feb 25 2021, 12:10 PM
That is not a stock knob (but a desirable one IMO) and the bushing is not the stock part #2. I would remove the fluted bushing and either helicoil the set screw hole or tap it for the next size up screw. Then glue the bushing back into the knob, put it back on the lever, and tighten the now functioning set screw.
I don't see the crush bushing on yours, nor do I believe you use it with that style of knob. I have a similar know but it is a true press fit (no set screw) that also does not use the crush bushing. |
VaccaRabite |
Feb 25 2021, 12:11 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You have some weirdness going on there, and it took me a minute to figure out what was going on.
The knob is aftermarket I think. And when you pulled the knob off the shifter you actually pulled the knob apart. The base of the knob is still attached to the shifter lever. That is not part 2 in your diagram. Part 2 is likely wedged between the knob base and the shifter lever. OR The person glued the knob to the shifter lever when they installed that aftermarket center console. HOPE HOPE HOPE its the first thing and not the second. ASSUMING ITS NOT GLUED: To remove the base, you need to tap under it with a hammer. I usually use an open ended wrench (15mm) to get more surface area around the base of the knob. Then smack it upwards with a hammer. Or with the knob broken as it is you could probably use a gear puller or a slide hammer to get it off. If the PO was lazy and just epoxied the knob to the shaft you may be in a world of suck. Try the same thing as above and maybe the glue shears. Under no circumstances do you want to be the next owners DAPO and glue the knob back on the shaft. Zach |
stickyfingers |
Feb 25 2021, 12:13 PM
Thanks guys. I want to do this right - this vehicle isn't going anyways and I plan on enjoying for a very long time - so I want to go as original as possible. I'll give that a ship and hopefully it isn't epoxied.
Tom_T |
Feb 25 2021, 12:24 PM
You've got the aftermarket AMCO shift knob that was sold by the dealers & suppliers back in the day (my 73 has the same knob), as is the center console. #2 is not a screw, but is the retaining clip which is still sold by Porsche etc. & applies to the stock & these other knobs from the 1960s-80s - so they still carry them for the 911/912/930, etc. - as well as for the 914-6 & 914 /4s, same part for all models & years. Buy 2 since they're cheap & you'll have a back-up. The clip will allow the AMCO knob's set-screw to engage - especially if it's stripped or worn down the teeth at the lever. Also check that it's the proper length set-screw, & replace that for a longer one if too short, broken off or worn at the end of the set-screw. If you haven't done so yet - go to the Porsche website, Classic section, under its Documents subsection, & download your free pdf Porsche 914 PET parts manual, which has those types of diagrams, along with the parts numbers, sub-model & year application, etc. as needed to order. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
stickyfingers |
Feb 25 2021, 12:26 PM
This is amazing information and thank you for the prompt reply. I'll go and do that.
ClayPerrine |
Feb 25 2021, 12:28 PM
@scottthephotog has the rear bumper bar and the luggage rack, just like the pictures above.
His 914 is even yellow, just like the pictures. Clay |
Mikey914 |
Feb 25 2021, 12:31 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Thanks guys. I want to do this right - this vehicle isn't going anyways and I plan on enjoying for a very long time - so I want to go as original as possible. I'll give that a ship and hopefully it isn't epoxied. Good news is the epoxy has a hard time sticking to the chrome. You still may be able to tap it off. |
stickyfingers |
Feb 25 2021, 12:32 PM
Going to try that now - will keep you posted.
Tom_T |
Feb 25 2021, 12:34 PM
You have some weirdness going on there, and it took me a minute to figure out what was going on. The knob is aftermarket I think. And when you pulled the knob off the shifter you actually pulled the knob apart. The base of the knob is still attached to the shifter lever. That is not part 2 in your diagram. Part 2 is likely wedged between the knob base and the shifter lever. OR The person glued the knob to the shifter lever when they installed that aftermarket center console. HOPE HOPE HOPE its the first thing and not the second. ASSUMING ITS NOT GLUED: To remove the base, you need to tap under it with a hammer. I usually use an open ended wrench (15mm) to get more surface area around the base of the knob. Then smack it upwards with a hammer. Or with the knob broken as it is you could probably use a gear puller or a slide hammer to get it off. If the PO was lazy and just epoxied the knob to the shaft you may be in a world of suck. Try the same thing as above and maybe the glue shears. Under no circumstances do you want to be the next owners DAPO and glue the knob back on the shaft. Zach Yes it's the AMCO aftermarket knob, & yes it's the ribbed insert that goes into the base of the knob that is sitting on the top of the gear shift lever. Remove the knob insert from the shaft - you may need to use a solvent appropriate to whatever glue that a DAPO used if it's glued to the shift lever (google for what solvent for what adhesive). Be careful to put some plastic &/or aluminum foil tight around the base of the shift knob with old rag or something to catch the solvent that may run down the shift lever, that could damage the center console plastic. Then carefully re-glue the insert into the base of the knob itself - being careful NOT to get any inside of the shaft hole nor in the area around the set screw. The check the set screw length & condition as above, replace if necessary, & use the crush sleeve if necessary to grab it - or if it's the version of the AMCO know without the set screw. PS - You may want to check out these 914 resources by other members too - p914.com (.net & .org too) https://bowlsby.net/914/Classic/ https://bowlsby.net/914/WiringHarnesses/ Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
stickyfingers |
Feb 25 2021, 12:46 PM
You have some weirdness going on there, and it took me a minute to figure out what was going on. The knob is aftermarket I think. And when you pulled the knob off the shifter you actually pulled the knob apart. The base of the knob is still attached to the shifter lever. That is not part 2 in your diagram. Part 2 is likely wedged between the knob base and the shifter lever. OR The person glued the knob to the shifter lever when they installed that aftermarket center console. HOPE HOPE HOPE its the first thing and not the second. ASSUMING ITS NOT GLUED: To remove the base, you need to tap under it with a hammer. I usually use an open ended wrench (15mm) to get more surface area around the base of the knob. Then smack it upwards with a hammer. Or with the knob broken as it is you could probably use a gear puller or a slide hammer to get it off. If the PO was lazy and just epoxied the knob to the shaft you may be in a world of suck. Try the same thing as above and maybe the glue shears. Under no circumstances do you want to be the next owners DAPO and glue the knob back on the shaft. Zach Yes it's the AMCO aftermarket knob, & yes it's the ribbed insert that goes into the base of the knob that is sitting on the top of the gear shift lever. Remove the knob insert from the shaft - you may need to use a solvent appropriate to whatever glue that a DAPO used if it's glued to the shift lever (google for what solvent for what adhesive). Be careful to put some plastic &/or aluminum foil tight around the base of the shift knob with old rag or something to catch the solvent that may run down the shift lever, that could damage the center console plastic. Then carefully re-glue the insert into the base of the knob itself - being careful NOT to get any inside of the shaft hole nor in the area around the set screw. The check the set screw length & condition as above, replace if necessary, & use the crush sleeve if necessary to grab it - or if it's the version of the AMCO know without the set screw. PS - You may want to check out these 914 resources by other members too - p914.com (.net & .org too) https://bowlsby.net/914/Classic/ https://bowlsby.net/914/WiringHarnesses/ Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Thanks Tom. Will give that a shot. |
Jamie |
Feb 25 2021, 01:27 PM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
You have some weirdness going on there, and it took me a minute to figure out what was going on. The knob is aftermarket I think. And when you pulled the knob off the shifter you actually pulled the knob apart. The base of the knob is still attached to the shifter lever. That is not part 2 in your diagram. Part 2 is likely wedged between the knob base and the shifter lever. OR The person glued the knob to the shifter lever when they installed that aftermarket center console. HOPE HOPE HOPE its the first thing and not the second. ASSUMING ITS NOT GLUED: To remove the base, you need to tap under it with a hammer. I usually use an open ended wrench (15mm) to get more surface area around the base of the knob. Then smack it upwards with a hammer. Or with the knob broken as it is you could probably use a gear puller or a slide hammer to get it off. If the PO was lazy and just epoxied the knob to the shaft you may be in a world of suck. Try the same thing as above and maybe the glue shears. Under no circumstances do you want to be the next owners DAPO and glue the knob back on the shaft. Zach Yes it's the AMCO aftermarket knob, & yes it's the ribbed insert that goes into the base of the knob that is sitting on the top of the gear shift lever. Remove the knob insert from the shaft - you may need to use a solvent appropriate to whatever glue that a DAPO used if it's glued to the shift lever (google for what solvent for what adhesive). Be careful to put some plastic &/or aluminum foil tight around the base of the shift knob with old rag or something to catch the solvent that may run down the shift lever, that could damage the center console plastic. Then carefully re-glue the insert into the base of the knob itself - being careful NOT to get any inside of the shaft hole nor in the area around the set screw. The check the set screw length & condition as above, replace if necessary, & use the crush sleeve if necessary to grab it - or if it's the version of the AMCO know without the set screw. PS - You may want to check out these 914 resources by other members too - p914.com (.net & .org too) https://bowlsby.net/914/Classic/ https://bowlsby.net/914/WiringHarnesses/ Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Thanks Tom. Will give that a shot. If the insert is stuck on the shaft with something like epoxy, then heat from a heat gun is your solution rather than a solvent. (IMG:style_emoticons/default/poke.gif) |
stickyfingers |
Feb 25 2021, 01:57 PM
Cheers. Thx.
rhodyguy |
Feb 25 2021, 03:27 PM
Is that the Allen head set screw just visible in the knob base in the second picture? If not epoxied on, the base still on the lever should come off after removing the screw. Before you go hard core with epoxy, make sure the R/1st plate, lever wear, and the rest in the base housing are in top shape. Once you glue the knob on you can't get the lever out for service. Unless you cut the lever.
stickyfingers |
Feb 25 2021, 03:40 PM
Unfortunately the screw is there for show. It’s lose and doesn’t fit so it doesn’t do anything. I’ve removed it but can’t get the other piece off.
Tom_T |
Feb 25 2021, 03:42 PM
Is that the Allen head set screw just visible in the knob base in the second picture? If not epoxied on, the base still on the lever should come off after removing the screw. Before you go hard core with epoxy, make sure the R/1st plate, lever wear, and the rest in the base housing are in top shape. Once you glue the knob on you can't get the lever out for service. Unless you cut the lever. To be clear - do NOT glue the knob on the gear shift lever shaft! I said to remove the shift knob INSERT from the lever shaft - heat or solvent as appropriate - we don't know what adhesive was used if any Rhody (IMG:style_emoticons/default/poke.gif) And yes, try the set screw in the knob insert first to see if that lets it loose of the shaft. It's entirely possible that someone just yanked the knob off & it came off at the insert. (IMG:style_emoticons/default/dry.gif) Jeesh! (IMG:style_emoticons/default/dead horse.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 16th May 2024 - 07:20 AM |
