Tangerine fuel lines, Which hose to use? |
Planeswalker33 |
Feb 27 2021, 12:15 PM
Newbie Group: Members Posts: 23 Joined: 27-May 20 From: Southern California Member No.: 24,319 Region Association: Southern California |
I’m installing a complete set from Tangerine racing to replace the lines on my 75 1.8l. I’m confused on two portions.
First, where should I use the elbows that come with the kit? Second, can I just use the 7.9mm fuel hose to attaché the stainless tubes from the tunnel to those in the engine bay? I feel like I’m supposed to use the elbows with smaller hose there. Last the tubes in the engine bay are snug and pushing against each other slightly and will not fit into the lower clips. Am I fitting this wrong? I’m concerned they’ll rattle the way they are currently only in grommets and the upper fitting. I appreciate any help. Still very new to all this. Thanks! Attached thumbnail(s) |
sjhenry1075 |
Mar 1 2021, 08:22 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Make sure you use fuel line specifically designed for your setup. If you have FI you'll need something that can handle high pressure, otherwise you'll have a lot of leaks.. (ask me how I know..)
Lo-Fi Version | Time is now: 17th May 2024 - 12:06 AM |
