Windshield replacement, Finally going to do it |
DavidSweden |
Mar 1 2021, 10:56 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am finally going to replace the windshield.
I am assuming that if I use the Rubber Replacement for Windshield Molding from 914 Rubber I only need the new windshield, the rubber replacement and butyl tape to complete the windshield installation, no need for clips or spacers, is this correct? Thanks in advance |
bdstone914 |
Mar 1 2021, 11:10 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I am finally going to replace the windshield. I am assuming that if I use the Rubber Replacement for Windshield Molding from 914 Rubber I only need the new windshield, the rubber replacement and butyl tape to complete the windshield installation, no need for clips or spacers, is this correct? Thanks in advance You need a couple spacers at the bottom to center the windshield top to bottom. They are nothing special. I use a couple pieces of paint stiring sticks which are about 4mm thick. |
DavidSweden |
Mar 1 2021, 11:34 AM
I am finally going to replace the windshield. I am assuming that if I use the Rubber Replacement for Windshield Molding from 914 Rubber I only need the new windshield, the rubber replacement and butyl tape to complete the windshield installation, no need for clips or spacers, is this correct? Thanks in advance You need a couple spacers at the bottom to center the windshield top to bottom. They are nothing special. I use a couple pieces of paint stiring sticks which are about 4mm thick. Thanks, just to be sure that I understand, do you mean that the spacers are placed under the bottom edge of the glass to get the correct position and then removed after the glass is in place? Thanks in advance |
914werke |
Mar 1 2021, 11:48 AM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
You need a couple spacers at the bottom to center the windshield top to bottom. They are nothing special. I use a couple pieces of paint stiring sticks which are about 4mm thick. just to be sure that I understand, do you mean that the spacers are placed under the bottom edge of the glass to get the correct position and then removed after the glass is in place? No if you are using Buytl it should never really harden so on a hot summer day w/o the support blocks, the wieght of the glass can allow it to sag to the bottom of the frame. Leave them in. Attached thumbnail(s) |
RARE 6 |
Mar 1 2021, 11:52 AM
Member Group: Members Posts: 141 Joined: 18-January 15 From: Grand Junction CO Member No.: 18,337 Region Association: Rocky Mountains |
Spacers and clips are widely available and cheap. Got mine from Patrick Motorsports in Phoenix. Might was well do it right. Cheap enough insurance to make sure you're not later replacing that expensive windshield trim.
DavidSweden |
Mar 1 2021, 12:08 PM
Thanks for all the feedback.
Ok so I leave the spacers in place, this may be a stupid question but here goes- what keeps the spacers in position why don't they just fall off? Thanks in advance |
Robarabian |
Mar 1 2021, 12:46 PM
914 A Roo Group: Members Posts: 590 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
There are little holes behind the spacers. The new spacers "plug" into those holes. They stay in place by their own tension.
ndfrigi |
Mar 1 2021, 02:03 PM
chrome trim clips and windshield spacer pic for your idea.
available at 914rubber.com or pelicanparts and some other site. I did used 914rubber before on my previous 75. |
DavidSweden |
Mar 1 2021, 03:03 PM
Thanks for the help, much appreciated.
914werke |
Mar 1 2021, 03:28 PM
I just did one (windshield install) just before this WE.
I also used the Rubber ""clips" despite reading reports from other members that they had difficulty in they seemed prone to breaking. I also found this to be the case. (IMG:style_emoticons/default/sad.gif) Customer service was great in that they provided replacements but Id like to find a better (more plyable/flexable) alternative. I went that way because these things are pricy! It looks like you can still get the OE ones at about x2 the price, but does anyone have any experience with these since a lot of the OE Porsche parts aren't the same quality as the OG. |
914werke |
Mar 1 2021, 03:30 PM
BTW that spacer doesnt show dimensions but those look more like (identical to) the rubber spacers at the base of the rear window vs the OE windshield spacers I posted a pic of.
forrestkhaag |
Mar 1 2021, 03:32 PM
Am having my windshield and surrounding trim replaced under Hagerty zero deductible and Porsche dealer supplied glass and trim.
A tiny star chip went viral and triggers a full replacement. Done by Hagerty/Safelite Friday this week / and yes, clips and spacers are essential to achieve a factory level install. they have a giant suction cup arm that dorps the windshield in 1/16" increments on to the stickyt stuff and against the bottom anti-sag spacers. As for a garage trick for placing the windshield against that brutal....rubber adhesive (MS on purpose)..... if the windshield "lands" on the adhesive or windscreen frame eschew, you too be e screwed...... That stuff is unforgiving and, like Apollo 13, leaves no room for error in the landing. In your moon shot, I suggest using more BSSS and take your time. By placing and taping flat, several Bruce Stone Stir Sticks around the upper and side perimeter, bring in the glass with a helper (who you have vetted and does not drink or smoke weed and who has no dizzying interest in your wife), then get it positioned before pulling the BSSS's one by one after your are fully on the bottom spacers. (IMG:style_emoticons/default/beerchug.gif) |
bbrock |
Mar 1 2021, 07:36 PM
I just did one (windshield install) just before this WE. I also used the Rubber ""clips" despite reading reports from other members that they had difficulty in they seemed prone to breaking. I also found this to be the case. (IMG:style_emoticons/default/sad.gif) Customer service was great in that they provided replacements but Id like to find a better (more plyable/flexable) alternative. I went that way because these things are pricy! It looks like you can still get the OE ones at about x2 the price, but does anyone have any experience with these since a lot of the OE Porsche parts aren't the same quality as the OG. I have a bag of OE clips ready to go in IF I ever get the windshield I've had on order almost a year now (long story). I bought them after reading another thread about the repro clips prone to breaking and someone (can't remember who) said they had good luck with the OE clips. |
mb911 |
Mar 2 2021, 06:31 AM
914 Guru Group: Members Posts: 6,812 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I had a 70 914 that had metal molding clips.. I dont know why they stopped doing that.
jim_hoyland |
Mar 2 2021, 06:41 AM
Get that VIN ? Group: Members Posts: 9,262 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Forrest: Does safelite sell replacement windshields for the 914; or, did they just do the installation ?
forrestkhaag |
Mar 2 2021, 11:29 AM
Safelite (in north Scottsdale) had to order the parts including the trim, three clips, and Porsche dealer to supply the glass. Goes in in two days / I will update.
Sidebar: Do I remember that you too have a Boxster?.... or is that the fog of age setting in........ ? (IMG:style_emoticons/default/beerchug.gif) |
iankarr |
Mar 2 2021, 12:19 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Just a heads up that, in NY at least, Safelite won't install using butyl (as the factory did). They use urethane, which is much more rigid, per the law. There have been stories of people with urethane installations having cracked windshields since there's less give...
914werke |
Mar 2 2021, 12:38 PM
Same here in WA, not stories ... its happened to me
jim_hoyland |
Mar 2 2021, 01:15 PM
Safelite (in north Scottsdale) had to order the parts including the trim, three clips, and Porsche dealer to supply the glass. Goes in in two days / I will update. Sidebar: Do I remember that you too have a Boxster?.... or is that the fog of age setting in........ ? (IMG:style_emoticons/default/beerchug.gif) Yup Sold the white ‘98 to my neighbor and bought the red one from a PCA member who had taken meticulas care of the car. Really like driving it... (IMG:style_emoticons/default/smile.gif) Attached image(s) |
DavidSweden |
Mar 10 2021, 02:00 PM
I have ordered my new windshield and was just checking some old install threads when I came across this posted by Mikey914
If you are using the rubber to replace the chrome you will need to use urethane to install. You will not need the windshield spacer block or clips. You will want someone with a steady hand to make the bead as without the extra 1/2" of metal to hide the bead you can see it so it must be pretty. I am planning on using the 914 rubber around the windshield instead of the aluminium trim. Can anyone confirm that urethane is the way to go? Edit: here's the thread if anyone is interested: |
Lo-Fi Version | Time is now: 26th April 2024 - 06:34 AM |
