Windshield replacement, Finally going to do it |
DavidSweden |
Mar 1 2021, 10:56 AM
Member Group: Members Posts: 479 Joined: 8-June 14 From: Sweden Member No.: 17,452 Region Association: Scandinavia |
I am finally going to replace the windshield.
I am assuming that if I use the Rubber Replacement for Windshield Molding from 914 Rubber I only need the new windshield, the rubber replacement and butyl tape to complete the windshield installation, no need for clips or spacers, is this correct? Thanks in advance |
914werke |
Mar 1 2021, 11:48 AM
"I got blisters on me fingers" Group: Members Posts: 10,070 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
You need a couple spacers at the bottom to center the windshield top to bottom. They are nothing special. I use a couple pieces of paint stiring sticks which are about 4mm thick. just to be sure that I understand, do you mean that the spacers are placed under the bottom edge of the glass to get the correct position and then removed after the glass is in place? No if you are using Buytl it should never really harden so on a hot summer day w/o the support blocks, the wieght of the glass can allow it to sag to the bottom of the frame. Leave them in. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 10:29 PM |
