1973 Porsche 914 w/ 6-cyl Corvair conversion, @ Oakland pick-n-pull |
Jul 25 2005, 04:03 PM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i could run over there and have a look. but i don't have a camera right now, can you wait 'til thursday? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Andy |
bondo |
Jul 25 2005, 07:02 PM
I don't think they allow cameras, but if you can sneak one in.. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I'm in no big hurry.
ClayPerrine |
Jul 25 2005, 09:18 PM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
911 transmissions run in the exact same direction as a 914 transmission. The only difference is the locaiton of the ring gear. That is why it drives in the opposite direction. Even in reverse the input shaft runs the same direction, and the pinion shaft is turned in reverse at low speed , and for a short time only. If you reverse the rotation of the input shaft on a transmission, every internal part runs in the opposite direction. The shafts have thrust bearings that take the load caused by the helical cut gears. If you reverse the rotation of the shafts, you are running against surfaces that were not designed to take a thrust load. The only proper way to make a Corvair motor to a 901 transmission is to install a reverse rotation cam in the Corvair motor. Cap'n.. Can I get your input on this???? |
bd1308 |
Jul 25 2005, 10:09 PM
yea (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) i remembered right.
Lo-Fi Version | Time is now: 29th April 2024 - 12:30 PM |
