GB 123ignition, Now offering bluetooth for DJET |
timothy_nd28 |
Mar 1 2021, 04:10 PM
Group Buy ending in less than 1 week!
I have heard nothing but great things about this aftermarket distributor. I won't be part or this group buy, because I already purchased one a few weeks ago for my Ljet. While speaking with Ed at 123ignition, I told him that it might be good time to set up a group buy for the month of March, to help get our 914's running better for summer driving (IMG:style_emoticons/default/driving.gif) Ed told me: 1-5 people will get 5% off. 6-10 people, would be 10% off. 11+ people, is 10% off and free shipping within the US. Pretty sure Ed said that if we get 1000 people, he would fly out to each of our houses and personally install the new dizzy himself! (kidding) Group Buy 3/1/2021 thru 3/31/2021 Coupon code: 914world21 Please order using this site: 123ignitionusa.com I borrowed some links from the last group buy (thanks Rob)! Ed mentioned that the Djet version dizzy still does not have the bluetooth function. * Newest bluetooth model for D-jet 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. This group buy will also apply for other engines such as the 911 six cylinders. https://www.youtube.com/watch?v=3wZ2xj6SAfI |
mate914 |
Mar 8 2021, 08:08 AM
Matt Group: Members Posts: 748 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
What happens if you have the bluetooth+ and you use the immobilizer to lock your $80000 car and you loose(stolen) your phone? Is there a backup way of unlocking it?
Can the vacuum be disabled if not wanted? Matt |
123ignitionusa |
Mar 8 2021, 12:16 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
What happens if you have the bluetooth+ and you use the immobilizer to lock your $80000 car and you loose(stolen) your phone? Is there a backup way of unlocking it? Can the vacuum be disabled if not wanted? Matt Hi Matt Both good questions. For question one follow the reset instructions. To Reset: - Shut down the Apps on all devices! and disable Bluetooth on phone and tablet. (very important) - Shut off the ignition key - Connect the black wire of the ignition to the red wire ( + of the coil ), At this point there is no power on the Red/Black wire. - Turn ON the ignition key ( red and black wire are both powered by 12 Volt now ) Note: this can take as much as 30 seconds. Don't hurry it. - The blue LED will flash for about 10 seconds. - After the reset procedure is finished the blue LED will turn constantly ON. - Turn OFF the ignition key, and wire everything back to normal. - Now the code is 1234. - This will reset the unit but not delete the stored curve. As for number 2 simply don't hook it up or zero it out. No vacuum = no signal to energize the circuitry Ed |
Lo-Fi Version | Time is now: 12th May 2024 - 09:29 AM |
