GB 123ignition, Now offering bluetooth for DJET |
timothy_nd28 |
Mar 1 2021, 04:10 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Group Buy ending in less than 1 week!
I have heard nothing but great things about this aftermarket distributor. I won't be part or this group buy, because I already purchased one a few weeks ago for my Ljet. While speaking with Ed at 123ignition, I told him that it might be good time to set up a group buy for the month of March, to help get our 914's running better for summer driving (IMG:style_emoticons/default/driving.gif) Ed told me: 1-5 people will get 5% off. 6-10 people, would be 10% off. 11+ people, is 10% off and free shipping within the US. Pretty sure Ed said that if we get 1000 people, he would fly out to each of our houses and personally install the new dizzy himself! (kidding) Group Buy 3/1/2021 thru 3/31/2021 Coupon code: 914world21 Please order using this site: 123ignitionusa.com I borrowed some links from the last group buy (thanks Rob)! Ed mentioned that the Djet version dizzy still does not have the bluetooth function. * Newest bluetooth model for D-jet 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. This group buy will also apply for other engines such as the 911 six cylinders. https://www.youtube.com/watch?v=3wZ2xj6SAfI |
CMONNETT |
Mar 19 2021, 10:08 AM
Member Group: Members Posts: 150 Joined: 27-September 07 From: Cibolo, TX Member No.: 8,162 Region Association: Southwest Region |
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since.
Thanks, Chris |
rjames |
Mar 19 2021, 11:35 AM
I'm made of metal Group: Members Posts: 3,928 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since. Thanks, Chris What were the symptoms, or did it just completely stop working one day? |
CMONNETT |
Mar 19 2021, 03:00 PM
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since. Thanks, Chris What were the symptoms, or did it just completely stop working one day? At first it started with a real faint stumble, then the car would just start bucking real bad and finally died on the hwy. Had it towed home, and the thing fired up like nothing once it got off the truck. It was the first time I have ever had to tow the car in the 20yrs of ownership. It drove fine for a few days and started acting up again, swapped out the dizzy on the side of the road, and it's been fine since. I would send it back, but was told it's only a one year warranty. |
123ignitionusa |
Mar 19 2021, 03:18 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since. Thanks, Chris What were the symptoms, or did it just completely stop working one day? At first it started with a real faint stumble, then the car would just start bucking real bad and finally died on the hwy. Had it towed home, and the thing fired up like nothing once it got off the truck. It was the first time I have ever had to tow the car in the 20yrs of ownership. It drove fine for a few days and started acting up again, swapped out the dizzy on the side of the road, and it's been fine since. I would send it back, but was told it's only a one year warranty. If you want to send it in to me I can check it out. Let you know what is wrong and give you an estimate to fix. Hope this helps Ed |
CMONNETT |
Mar 19 2021, 03:48 PM
Has anyone else had a problem with these 123's cutting out? I bought one for D-Jet on the first group buy to install when I finished my 2056 build. The thing didn't even last 1000mi. I finally just put the stock dizzy back in, and the car hasn't given me an issue since. Thanks, Chris What were the symptoms, or did it just completely stop working one day? At first it started with a real faint stumble, then the car would just start bucking real bad and finally died on the hwy. Had it towed home, and the thing fired up like nothing once it got off the truck. It was the first time I have ever had to tow the car in the 20yrs of ownership. It drove fine for a few days and started acting up again, swapped out the dizzy on the side of the road, and it's been fine since. I would send it back, but was told it's only a one year warranty. If you want to send it in to me I can check it out. Let you know what is wrong and give you an estimate to fix. Hope this helps Ed That would be great! Thanks |
Lo-Fi Version | Time is now: 12th May 2024 - 10:25 PM |
