GB 123ignition, Now offering bluetooth for DJET |
timothy_nd28 |
Mar 1 2021, 04:10 PM
Group Buy ending in less than 1 week!
I have heard nothing but great things about this aftermarket distributor. I won't be part or this group buy, because I already purchased one a few weeks ago for my Ljet. While speaking with Ed at 123ignition, I told him that it might be good time to set up a group buy for the month of March, to help get our 914's running better for summer driving (IMG:style_emoticons/default/driving.gif) Ed told me: 1-5 people will get 5% off. 6-10 people, would be 10% off. 11+ people, is 10% off and free shipping within the US. Pretty sure Ed said that if we get 1000 people, he would fly out to each of our houses and personally install the new dizzy himself! (kidding) Group Buy 3/1/2021 thru 3/31/2021 Coupon code: 914world21 Please order using this site: 123ignitionusa.com I borrowed some links from the last group buy (thanks Rob)! Ed mentioned that the Djet version dizzy still does not have the bluetooth function. * Newest bluetooth model for D-jet 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. This group buy will also apply for other engines such as the 911 six cylinders. https://www.youtube.com/watch?v=3wZ2xj6SAfI |
914chris |
Mar 31 2021, 11:03 AM
Newbie Group: Members Posts: 23 Joined: 30-August 05 From: Santa Clarita, CA Member No.: 4,701 Region Association: None |
For a 914/6 application on original 2.0 liter 6, would I remove the CDI?
Website description says: Suitable for engines without HKZ (CDI) unit and first generation HKZ unit ( 3 wires ) Warning: Don’t use the original HKZ (CDI) coil direct on the 123ignition. I believe I have the HKZ unit with 3 wires. Says it is suitable to use with first gen, but then says don't use it direct on the 123ignition. What does "direct on" mean? |
123ignitionusa |
Mar 31 2021, 06:19 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
For a 914/6 application on original 2.0 liter 6, would I remove the CDI? Website description says: Suitable for engines without HKZ (CDI) unit and first generation HKZ unit ( 3 wires ) Warning: Don’t use the original HKZ (CDI) coil direct on the 123ignition. I believe I have the HKZ unit with 3 wires. Says it is suitable to use with first gen, but then says don't use it direct on the 123ignition. What does "direct on" mean? Hi I am not sure how they are wired. So I cannot answer that tonight as the mfg is closed at the moment. I will extend the buy 24hrs to see if I can get an answer. As for the gear - There are two different pitched gears depending on what motor you have. The 2.4 2.7 and 3.3 when looking at them sitting in front of you are pitched from left up to the right. The 3.0 SC is pitched from right to up to the left. Over the years motors are worked on and rearranged cams from different motors are used and gearing changes. Because of this you need to confirm what you have. A picture is supplied to compare. Almost all are pitched from left up to the right. I have had customers order one only to find out they have the other. You mus to a visual comparison. See attachment In addition original gears have a larger inside diameter than the 123 and so cannot be used unless a bushing adapter is used. 123ignitionusa Webpage Attached thumbnail(s) |
Lo-Fi Version | Time is now: 13th May 2024 - 10:56 AM |
