GB 123ignition, Now offering bluetooth for DJET |
timothy_nd28 |
Mar 1 2021, 04:10 PM
Group Buy ending in less than 1 week!
I have heard nothing but great things about this aftermarket distributor. I won't be part or this group buy, because I already purchased one a few weeks ago for my Ljet. While speaking with Ed at 123ignition, I told him that it might be good time to set up a group buy for the month of March, to help get our 914's running better for summer driving (IMG:style_emoticons/default/driving.gif) Ed told me: 1-5 people will get 5% off. 6-10 people, would be 10% off. 11+ people, is 10% off and free shipping within the US. Pretty sure Ed said that if we get 1000 people, he would fly out to each of our houses and personally install the new dizzy himself! (kidding) Group Buy 3/1/2021 thru 3/31/2021 Coupon code: 914world21 Please order using this site: 123ignitionusa.com I borrowed some links from the last group buy (thanks Rob)! Ed mentioned that the Djet version dizzy still does not have the bluetooth function. * Newest bluetooth model for D-jet 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. This group buy will also apply for other engines such as the 911 six cylinders. https://www.youtube.com/watch?v=3wZ2xj6SAfI |
914chris |
Mar 31 2021, 11:03 AM
Newbie Group: Members Posts: 23 Joined: 30-August 05 From: Santa Clarita, CA Member No.: 4,701 Region Association: None |
For a 914/6 application on original 2.0 liter 6, would I remove the CDI?
Website description says: Suitable for engines without HKZ (CDI) unit and first generation HKZ unit ( 3 wires ) Warning: Don’t use the original HKZ (CDI) coil direct on the 123ignition. I believe I have the HKZ unit with 3 wires. Says it is suitable to use with first gen, but then says don't use it direct on the 123ignition. What does "direct on" mean? |
123ignitionusa |
Mar 31 2021, 06:26 PM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
For a 914/6 application on original 2.0 liter 6, would I remove the CDI? Website description says: Suitable for engines without HKZ (CDI) unit and first generation HKZ unit ( 3 wires ) Warning: Don’t use the original HKZ (CDI) coil direct on the 123ignition. I believe I have the HKZ unit with 3 wires. Says it is suitable to use with first gen, but then says don't use it direct on the 123ignition. What does "direct on" mean? You could remove the 3- pin unit and use it with a plain coil of not less than 1 ohm. I will email the mfg in the morning regarding the statement of not using the hkz direct and extend the special by 24 hrs. |
Lo-Fi Version | Time is now: 13th May 2024 - 04:00 AM |
