GB 123ignition, Now offering bluetooth for DJET |
timothy_nd28 |
Mar 1 2021, 04:10 PM
Group Buy ending in less than 1 week!
I have heard nothing but great things about this aftermarket distributor. I won't be part or this group buy, because I already purchased one a few weeks ago for my Ljet. While speaking with Ed at 123ignition, I told him that it might be good time to set up a group buy for the month of March, to help get our 914's running better for summer driving (IMG:style_emoticons/default/driving.gif) Ed told me: 1-5 people will get 5% off. 6-10 people, would be 10% off. 11+ people, is 10% off and free shipping within the US. Pretty sure Ed said that if we get 1000 people, he would fly out to each of our houses and personally install the new dizzy himself! (kidding) Group Buy 3/1/2021 thru 3/31/2021 Coupon code: 914world21 Please order using this site: 123ignitionusa.com I borrowed some links from the last group buy (thanks Rob)! Ed mentioned that the Djet version dizzy still does not have the bluetooth function. * Newest bluetooth model for D-jet 1. Hardcoded advance curves with no vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 2. Hardcoded advance curves with vacuum, no bluetooth, with no output for D-Jet Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. 3. Hardcoded advance curves with no vacuum, no bluetooth, with output for D-Jet This is the unit to choose for stock D-Jet users. 4. Custom bluetooth tunable advance curves with vacuum, with bluetooth, with no output for D-Jet. This is the best unit for carbs, L-Jet, aftermarket FI 5. Custom laptop tunable advance curves with vacuum, no bluetooth, with no output for D-Jet. Will work with engines that have carbs, L-Jet or aftermarket FI. Will not work with D-Jet. This group buy will also apply for other engines such as the 911 six cylinders. https://www.youtube.com/watch?v=3wZ2xj6SAfI |
123ignitionusa |
Apr 1 2021, 06:36 AM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
This should end the confusion regarding the Hkz CDI and the 123ignition.
From Ron at the Mfg "You can use our 123Ignition distributor without the HKZ unit. But you can't use the Coil from the HKZ unit directly on our 123Ignition distributor. This coil has a resistance of 0,4 Ohm. Our 123ignition needs a coil of at least 1 ohm." So Bottom line is 1) Yes you can use the HKZ 3 pin CDI system. 2) Do not use the original coil change it out for one that measures 1 ohm or higher. Like a Bosch Red (1.8 ohm) or a Bosch Blue (3.4 ohm). Sale ends tonight at midnight EST. Unfulfilled orders are being shipped from the mfg as we speak. Shipping to you should be middle of next week Hope this helps Ed |
Lo-Fi Version | Time is now: 12th May 2024 - 09:24 AM |
