| timothy_nd28 |
Oct 17 2021, 07:25 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest
So I just now installed this bluetooth 123 dizzy on my Ljet, and wow! My 914 has been down for the past few years, and I have been slowly bringing it back to life this past week by installing a gowesty throttle body, new fuel injectors, high torque starter. Not only did it start on the first crank, it ran pretty damn well despite one of my new fuel injectors was not firing, causing my car to run on only three cylinders. After replacing the new faulty injector with new again (FJ707), I'm running on all 4 cylinders and this car has never ever ran this smooth before, simply amazing. I did a generic timing of 30 degrees at 3000 rpm, just to be in the ball park, but I plan to use Pete's curve to see if it changes the performance, seems pretty flat trying to accelerate. I haven't messed with any timing curves internal to the 123 dizzy, whatever is pre programmed out of the box is what I'm using, so this may explain why it's somewhat flat on acceleration.
I'm very impressed so far, thanks again everyone who participated in this group buy |
| Front yard mechanic |
Oct 17 2021, 07:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
So I just now installed this bluetooth 123 dizzy on my Ljet, and wow! My 914 has been down for the past few years, and I have been slowly bringing it back to life this past week by installing a gowesty throttle body, new fuel injectors, high torque starter. Not only did it start on the first crank, it ran pretty damn well despite one of my new fuel injectors was not firing, causing my car to run on only three cylinders. After replacing the new faulty injector with new again (FJ707), I'm running on all 4 cylinders and this car has never ever ran this smooth before, simply amazing. I did a generic timing of 30 degrees at 3000 rpm, just to be in the ball park, but I plan to use Pete's curve to see if it changes the performance, seems pretty flat trying to accelerate. I haven't messed with any timing curves internal to the 123 dizzy, whatever is pre programmed out of the box is what I'm using, so this may explain why it's somewhat flat on acceleration. I'm very impressed so far, thanks again everyone who participated in this group buy Another group buy? |
| 123ignitionusa |
Oct 26 2021, 06:53 PM
Member ![]() ![]() Group: Members Posts: 63 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
So I just now installed this bluetooth 123 dizzy on my Ljet, and wow! My 914 has been down for the past few years, and I have been slowly bringing it back to life this past week by installing a gowesty throttle body, new fuel injectors, high torque starter. Not only did it start on the first crank, it ran pretty damn well despite one of my new fuel injectors was not firing, causing my car to run on only three cylinders. After replacing the new faulty injector with new again (FJ707), I'm running on all 4 cylinders and this car has never ever ran this smooth before, simply amazing. I did a generic timing of 30 degrees at 3000 rpm, just to be in the ball park, but I plan to use Pete's curve to see if it changes the performance, seems pretty flat trying to accelerate. I haven't messed with any timing curves internal to the 123 dizzy, whatever is pre programmed out of the box is what I'm using, so this may explain why it's somewhat flat on acceleration. I'm very impressed so far, thanks again everyone who participated in this group buy Hi Tim Just wanted to let you know the curve that comes with the Bluetooth is a generic curve not intended for any particular car. It does give you something to work with. If you have a Porsche specific curve you can load in it should help quite a bit. Don't forget to verify , synchronize the app with the motor. Hope this helps Ed |
| jcd914 |
Nov 15 2021, 11:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
So I just now installed this bluetooth 123 dizzy on my Ljet, and wow! My 914 has been down for the past few years, and I have been slowly bringing it back to life this past week by installing a gowesty throttle body, new fuel injectors, high torque starter. Not only did it start on the first crank, it ran pretty damn well despite one of my new fuel injectors was not firing, causing my car to run on only three cylinders. After replacing the new faulty injector with new again (FJ707), I'm running on all 4 cylinders and this car has never ever ran this smooth before, simply amazing. I did a generic timing of 30 degrees at 3000 rpm, just to be in the ball park, but I plan to use Pete's curve to see if it changes the performance, seems pretty flat trying to accelerate. I haven't messed with any timing curves internal to the 123 dizzy, whatever is pre programmed out of the box is what I'm using, so this may explain why it's somewhat flat on acceleration. I'm very impressed so far, thanks again everyone who participated in this group buy Another group buy? I would be interested. I have decided an ignition upgrade is due and will probably be buying a blue tooth version 123 shortly group buy or not. Jim There seemed to be some interest back in July when "wbgoggans" asked. Yes Yes |
| strawman |
Nov 16 2021, 07:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 891 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California
I'm interested in a group buy for my wife's 1975 L-Jet 914; I'd want the bluetooth version.
| 7275914911 |
Feb 21 2022, 10:00 PM
Hummmm!!! ![]() ![]() ![]() Group: Members Posts: 757 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States
Here is the curve I ended up with my 74 1.8 L-Jet. No vacuum used for either advance or retard. Thanks for sharing this info. Are there other Curves out there to be shared by others for the bluetooth version. Engine is a 2056 w/1.7 Djet with 2.0 injectors. 2056 is 1.8 case with 2.0 crank/rods/pistons. Thanks in advance for any and all replies, Ken |
| relentless |
Feb 22 2022, 02:44 PM
Member ![]() ![]() Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
I'd be in for another GB for my '76 d-jet.
| Van B |
Feb 22 2022, 02:51 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 20-October 21 From: WR, GA Member No.: 26,011 Region Association: None
I'm interested in a group buy for my wife's 1975 L-Jet 914; I'd want the bluetooth version. Same here for my '74 L-Jet. But, frankly, I'm a little worried it might be too much of a challenge to get right. I don't see any data on Vac advance/retard curves or RPM advance profiles. As one guy who's learning about distributors for the first time, I'm simply not up to the task. And without any experienced real-life 914 friends who are willing to help, I need a plug and play option. If 123ignition had base maps for the L-Jet, I would already be an owner. |
Lo-Fi Version | Time is now: 6th January 2026 - 10:36 PM |
