Spark Plug wires, What do you like? |
steuspeed |
Mar 8 2021, 01:23 PM
Senior Member Group: Members Posts: 1,006 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Looking for new wires. What do you like for a stock 2.0L?
Clewett, Magnacor, Denso, Bemi, Bosch, Beru, NGK other? |
VaccaRabite |
Mar 8 2021, 01:31 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Looking for new wires. What do you like for a stock 2.0L? Clewett, Magnacor, Denso, Bemi, Bosch, Beru, NGK other? For a stock car I'd get as close to stock wires as possible. You definitely do not need Magnacors with a stock motor. Any of the fancy spiral wound heavy insulated yadda yadda wires are just overkill. This changes when you go to modern EFI or more sensitive spark control. Zach |
mlindner |
Mar 8 2021, 03:23 PM
Senior Member Group: Members Posts: 1,522 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Well, I did need a set of wire with a long coil wire running to the MSD box on my 914-6 GT build. Called Clewett, (i think the owner 8:00 his time). Yup he understood the problem, had the set, asked how fast I wanted it...same day, two day. Just a great company to deal with. Best, Mark
wndsrfr |
Mar 8 2021, 08:38 PM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Well, I did need a set of wire with a long coil wire running to the MSD box on my 914-6 GT build. Called Clewett, (i think the owner 8:00 his time). Yup he understood the problem, had the set, asked how fast I wanted it...same day, two day. Just a great company to deal with. Best, Mark (IMG:style_emoticons/default/agree.gif) Clewett... |
steuspeed |
Mar 9 2021, 03:19 AM
Ordered one Clewett set on Rennline. I'll get another for the other car if I like it.
steuspeed |
Mar 10 2021, 03:46 AM
[/quote] For a stock car I'd get as close to stock wires as possible. You definitely do not need Magnacors with a stock motor. Any of the fancy spiral wound heavy insulated yadda yadda wires are just overkill. This changes when you go to modern EFI or more sensitive spark control. Zach [/quote] This car has Pertronix. The Outlaw ha a Crane FireBall SS ignition. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:42 AM |
