Steering wheel wobble |
rd914 |
Jul 19 2005, 11:15 AM
Newbie Group: Members Posts: 31 Joined: 13-April 05 From: San Diego, CA Member No.: 3,928 |
Is there is a sleeve that secures it in place? I took it apart last week to replace an ignition switch and did not see any. Pics would be appreciated. Thanks.
By the way, car is a 76 2.0. |
olav |
Jul 19 2005, 11:21 AM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
I just replaced my steering wheel and noticed that if I didn't include a little collar and spring part that fits into the spline shaft area with the spring out the steering wheel wobbled.
Sorry, don't have pics. You might have that piece missing or backwards. |
nebreitling |
Jul 19 2005, 11:25 AM
if you're talking about an verticle wobble, then yes, there is a bushing that wears out (it's plastic!) somewhere down in there. kind of a pita, iirc.
MarkG |
Jul 19 2005, 11:27 AM
Member Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
My '76 also had steering wheel wobble; bought the sleeve 'quick fix' but when I removed the hub, the steering column bearing was fine so..........
Remove knee pad and check two allen head screws that hold column to the body...mine were loose. Tighten'd them up and now no wobble! |
URY914 |
Jul 19 2005, 11:51 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,562 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Pelican sells a sleeve (I think it is a 928 part actully) that fits around the shaft and slides between the shaft and the larger bearing/bushing. I had to do on mine. I got a picture at home on my PC. The sleeve is split to get it over the splines of the shaft.
Lo-Fi Version | Time is now: 13th May 2024 - 11:20 PM |
