Smoke from below dizzy. (Pertronix) |
jaredmcginness |
Mar 13 2021, 06:10 PM
... Group: Members Posts: 502 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Hey guys, me again.
I dropped the motor yesterday, to pull the transmission. Put it back in today, turn key to first position, and I have (red) smoke coming from underneath the dizzy. (009 Petroniix) horrible smell. To be clear, All I unplugged was the 3 starter wires, 12pin and alt 3pin cable from the relay box. Not much to mess up here! Yet here I am! I’m carbed and my wiring is about as simple as it goes. I did find a short between the blower motor wires, repaired that. (Maybe they got caught in the tin while lowering? Same issue. Is it possible that once shorted initially the 009 is just toast? Thanks! |
Spoke |
Mar 13 2021, 07:22 PM
Jerry Group: Members Posts: 6,986 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Pertronix inductive points are quite robust unless you let the smoke out. Not sure what happened to your install but there isn't much wiring/electronics in the carbed dizzy. What did the module look like when you popped the distributor cap?
ejm |
Mar 13 2021, 07:31 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
jaredmcginness |
Mar 13 2021, 07:37 PM
Spoke, I’ll have to check inside the dizzy. I only had the ignition turned enough to step out and see the smoke. Wasn’t but a few seconds.
I’ll verify the 12 pin indexing, I try to take good care that nothing will come loose. |
Lo-Fi Version | Time is now: 26th May 2024 - 09:16 PM |
