Wiper Assembly Removal - Order of operations, do I have to remove the fresh air box?? |
moldygreg |
Mar 15 2021, 08:59 PM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
Was able to confirm the motor to the wiper assembly has seized. Thank you PowerProbe!
So I know I have to remove the gas tank. Does the fresh air intake need to be removed as well? I remember that being probably one of the most difficult components on the car to deal with. Hoping it does not need to removed, but maybe just loosened. Thanks! Greg |
914werke |
Mar 15 2021, 09:05 PM
"I got blisters on me fingers" Group: Members Posts: 10,097 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Yup. Be delicate. The bake-alight / plastic stuff under there is 50 yrs old & brittle.
There is also a rubber mount/isolater that needs to be disconnected. from under the dash inside the cabin |
moldygreg |
Mar 15 2021, 09:24 PM
Yup. Be delicate. The bake-alight / plastic stuff under there is 50 yrs old & brittle. There is also a rubber mount/isolater that needs to be disconnected. from under the dash inside the cabin (IMG:style_emoticons/default/hissyfit.gif) Oh No! THanks @914werke --- think goodness we don't get much rain in the good ole PNW, eh? regarding Rubber mount isolater, you're referencing the for the Wiper assemblery not Fressh Blower --- correct? Thanks! Greg |
framos914 |
Mar 15 2021, 09:25 PM
Member Group: Members Posts: 125 Joined: 15-May 14 From: Corona California Member No.: 17,353 Region Association: Southern California |
Yup. Be delicate. The bake-alight / plastic stuff under there is 50 yrs old & brittle. There is also a rubber mount/isolater that needs to be disconnected. from under the dash inside the cabin |
914werke |
Mar 15 2021, 09:26 PM
yup Ill try to find a pic.
Its just a 10mm m6 nut under the dash |
moldygreg |
Mar 15 2021, 09:31 PM
yup Ill try to find a pic. Its just a 10mm m6 nut under the dash Got it! No need for a pic .... yet. Will say an incantation before proceeding. (IMG:style_emoticons/default/stirthepot.gif) |
roblav1 |
Mar 15 2021, 09:52 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I've had two 914s absolutely completely apart, and that dang fresh air blower box is THE most difficult part of assembly!
Lo-Fi Version | Time is now: 25th May 2024 - 07:30 PM |
