A little more pep for all of you Carburated folks Out there. |
pcdarks |
Mar 18 2021, 02:43 PM
Member Group: Members Posts: 80 Joined: 22-June 13 Member No.: 16,037 Region Association: None |
This is something for you to try to get more pep when you first hit the gas. First of all read it through until you understand what I did. I switched over from FI to a center mount progressive two barrel carb but this would work with any carb configuration. I had the stock distributor with vacuum advance and retard. I hooked up the vacuum retard to ported vacuum on the carb. What this does it retards the timing at idle. I then timed the engine with the vacuum hooked up to factory specs. The engine idles as it should at around TDC. As I start to accelerate from a stop the vacuum drops and the retard in the distributor releases giving me a little timing advance and the engine takes off with more pep. This advance works until the engine catches up and vacuum increases causing the distributor to retard to stock timing. Now the mechanical advance works for the rest of the acceleration. If I am cruising in a higher gear and give it gas the distributor again advances when the retard losses vacuum when the pedal is pushed giving the car mare advance again until the engine increases vacuum where it then retards to factory timing. At cruise speeds. the distributor mechanically advances to 27 degrees and runs there until again acceleration causes the vacuum to drop and momentarily advances the timing. The car has very noticeably better take off from a stop and accelerates quicker at speed. try it.
Lo-Fi Version | Time is now: 19th May 2024 - 02:20 AM |
