QUOTE(pcdarks @ Mar 20 2021, 02:04 PM)
Been there done that. The timing advances to 27 degrees at 3200rpm. If the pedal is floored at cruising speed it will momentarily advance it further but for so short of a time it will cause no problems.
Assuming you are not actually verifying your timing while flooring it driving down the road... So what is happening here is the the minor load on your engine from accelerating it up to speed is enough to drop some vacuum and you lose the retard/timing over advances but once the RPM has stabilized it comes back down to 27. The problem is these are not the conditions you drive under and when you are actually under load while driving this is happening all the time.
Take a drive WOT up a long, steep grade on a hot day and report back...
PS. I have some spare motors sitting in my garage when you do.
Your timing is over advanced.
QUOTE(pcdarks @ Mar 19 2021, 08:32 AM)
I've also noticed that the car runs better when it's still a little cold. No stumbling. Has anyone tried this?
Advancing timing can help with cold idle, its actually a feature that they have built into Megasquirt for that reason (and im sure other injection systems) only with Megasquirt it dials back the advance once the engine is warm so you dont damage your engine by running to much advance all the time.
QUOTE(Mark Henry @ Mar 24 2021, 07:30 AM)
KELTY360 is correct, your title is misleading, really you need to suck it up or you won't be making any friends here and if you're serious about the 914 you will need help here from time to time.
I'm an engine builder, I've been into building VW 's over 30 years, and into the 914 for 20 years...I still get things wrong about these cars all the time, but I suck it up, learn and move on.
Come on Mark, dont be so harsh!
Ill help out anyone regardless of whatever differing beliefs they may hold about life, the universe, and everything.... and carbs. Just as long as they don't piss me off, and to date only one person on this board has managed to relieve themselves of me ever offering my input on their threads again. And lets be honest at this point with all the information out there on the shortcomings of the single carb setup on these cars anyone who still swears by them I just view as sort of having a religious belief, and I learned a long time ago not to get into arguments over peoples beliefs. Personally never been a fan of praying the the controlled fuel leak on top of my motor is delivering something near the optimal amount of fuel as i drive down the road. Me, I'm an engineer, I like data, that's why I run a system that can log it all!
More than happy to share findings from that data if it helps get people on the right track!
To your point though, I could see a car with dual carbs and a hot cam having an absolute trash vacuum signal that would throw the timing all over the place so yeah... probably wouldn't want to do something like that in that case... or at all, given the only thing going on here is over advanced timing.
