Outer firewall replacement, How do you get it past the heater tubes? |
worn |
Mar 22 2021, 06:02 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
The inner and outer firewall panels rusted where they meet the floor. This time around I bought the full-width outer firewall from Restoration Design. I may be able to manage to get the flapper box tubes and other through fittings brazed into place, but I can see no way to put the firewall panel in place with the heater tubes coming out of the longitudinal members. I don’t mind cutting the firewall and welding it back after installing it, but I sure would feel silly if there was a trick to it. Help please.
BeatNavy |
Mar 22 2021, 06:11 PM
I don’t mind cutting the firewall and welding it back after installing it That's what I ended up doing. I believe I'm not the only one, but I'll let others chime in. I remember noodling this through and not coming up with any other solution. You can see mine in place below and where I cut it to fit it in place. |
worn |
Mar 22 2021, 07:11 PM
Thanks! Any other ideas?
Literati914 |
Mar 22 2021, 08:57 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I've been wondering the same, hopefully someone will have a good idea and can share..
I've been contemplating cutting a 'heater-tube-width' section out on each side of the panel, then sliding the piece in place & welding the cut-outs back in. The out-side area of the tube holes seem like a better option than the bottom - 'cause the bottom is the more vulnerable areas for rust development (obviously). . |
cary |
Mar 22 2021, 11:54 PM
Can't be done. Cut and paste. The 2 45 degree tubes make it impossible.
Can only be done with both longs open and heater tubes removed. Rob did a nice job. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:24 PM |
