Literati914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,006 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region ![]() |
I have a set of 28 spline, 108mm shafts that were definitely running on a 914 before I got them (I only assume a 901 was being used, but never saw the transaxle). They came with a set of stock 5-lug rear hubs - as well as a set of trailing arm that had been modified to use a 911 E-brake set up (driver's side only).
I thought 108mm 911 axles wouldn't work with a stock 914 transaxle though - is that right? I'd like to find the part #s on these but they are super cruddy and I'm no-where near needing to rebuild & use them. The p/n's are not obvious, I figured they're probably under one of the CV boots - can someone confirm which (end/boot) I need to cut off to find it? TIA. . |
Lo-Fi Version | Time is now: 8th July 2025 - 10:47 AM |
