914-6 throttle hard to depress |
mb911 |
Mar 28 2021, 10:59 AM
914 Guru Group: Members Posts: 6,858 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
As my conversion nears the end I am working on all the odds and ends. I find the throttle is a bit hard to push. If the cable is disconnected there is no issue. I believe the issue is the bell crank area. Its almost as though it needs a spring to assist or a bigger mechanical advantage. Any advice.. ?
Lo-Fi Version | Time is now: 27th May 2024 - 01:22 AM |
