Main Targa seal, Not having any success |
Morph914 |
Apr 3 2021, 09:43 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I would take installing the air box 5 times, over putting this seal in. I cannot get it to conform at the top where it makes the bend. (IMG:style_emoticons/default/headbang.gif)
I have tried heating the rubber in this area to get it to conform to the bend without any luck. The 914 rubber piece is reinforced in the exact location that it needs to make the bend. Not sure what to do at this point. (IMG:style_emoticons/default/hissyfit.gif) You can see where the original piece is bent. |
forrestkhaag |
Apr 3 2021, 05:36 PM
I did this fix very recently and found that there is a small tab or blade of metal on the body at the two channel tops that became my starting point for installation. I pushed the 914 Rubber piece onto that tab, (and there may be a screw involved on some cars) and then proceeded to manhandle the corners into their correct fit.
The middle top of the seal was dangling as were the two channel pieces at that point but the two corners were tight and felt and looked rightish. I used a mixture of fruity soap, hand lotion, green liquid dish soap (color matters) and beer to lube the vertical channels and me and then pushed the interior side into the channel inch by inch with a well rounded 9" long plastic tool (used in the Tiffany method of stained glass/ copper foil artwork). Then with the careful application of more and more beer, and a careful dousing of the lube recipe noted herein, i pushed the exterior side of the channel-rubber into the aluminum channel. From the factory the aluminum channel is crimped to trap the factory seal so gently pry open that part of the channel or you will not get the vertical all in. Lastly, dont have any more beer and get out your new sharp 4" long blade and clamp it in vice grips, dip it in your lube solution and gently saw off the extra seal at the bottom AND NOTE HOW THE DOOR CLOSES TO FIND THE PERFECT ANGLE FOR THE BOTTOM CUT. Sidebar: If you screw it up (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/sheeplove.gif) , 914 Rubber has more for sale............ (IMG:style_emoticons/default/beerchug.gif) |
Morph914 |
Apr 3 2021, 08:45 PM
I did this fix very recently and found that there is a small tab or blade of metal on the body at the two channel tops that became my starting point for installation. I pushed the 914 Rubber piece onto that tab, (and there may be a screw involved on some cars) and then proceeded to manhandle the corners into their correct fit. The middle top of the seal was dangling as were the two channel pieces at that point but the two corners were tight and felt and looked rightish. I used a mixture of fruity soap, hand lotion, green liquid dish soap (color matters) and beer to lube the vertical channels and me and then pushed the interior side into the channel inch by inch with a well rounded 9" long plastic tool (used in the Tiffany method of stained glass/ copper foil artwork). Then with the careful application of more and more beer, and a careful dousing of the lube recipe noted herein, i pushed the exterior side of the channel-rubber into the aluminum channel. From the factory the aluminum channel is crimped to trap the factory seal so gently pry open that part of the channel or you will not get the vertical all in. Lastly, dont have any more beer and get out your new sharp 4" long blade and clamp it in vice grips, dip it in your lube solution and gently saw off the extra seal at the bottom AND NOTE HOW THE DOOR CLOSES TO FIND THE PERFECT ANGLE FOR THE BOTTOM CUT. Sidebar: If you screw it up (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/sheeplove.gif) , 914 Rubber has more for sale............ (IMG:style_emoticons/default/beerchug.gif) Beer! This is what was missing. I’ll try this method before my next attempt. (IMG:style_emoticons/default/beer3.gif) Honestly though, I have done all the things that have been mentioned. I had the top started and the interior lip in all the way down and started on the exterior side and the top opens up or pushes out like in the picture. I think I might train the part to make the bend at the top by fastening to a pipe and heating. And beer. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 26th May 2024 - 02:18 AM |
