Main Targa seal, Not having any success |
Morph914 |
Apr 3 2021, 09:43 AM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
I would take installing the air box 5 times, over putting this seal in. I cannot get it to conform at the top where it makes the bend. (IMG:style_emoticons/default/headbang.gif)
I have tried heating the rubber in this area to get it to conform to the bend without any luck. The 914 rubber piece is reinforced in the exact location that it needs to make the bend. Not sure what to do at this point. (IMG:style_emoticons/default/hissyfit.gif) You can see where the original piece is bent. |
PCH |
Apr 6 2021, 12:52 PM
Member Group: Members Posts: 141 Joined: 3-January 19 From: Santa Barbara Member No.: 22,772 Region Association: Southern California |
After spending the whole weekend unsuccessfully trying to install an aftermarket seal, I broke down and bought the very pricy Porsche seal.
In the end it was worth it-it only took me 15 minutes to install! |
horizontally-opposed |
Apr 7 2021, 10:12 AM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
After spending the whole weekend unsuccessfully trying to install an aftermarket seal, I broke down and bought the very pricy Porsche seal. In the end it was worth it-it only took me 15 minutes to install! ^ Hopefully, it will last longer than mine has, and allow your doors to close correctly? Maybe mine was from a bad batch, but 15 minutes sounds about right. |
PCH |
Apr 7 2021, 11:03 AM
After spending the whole weekend unsuccessfully trying to install an aftermarket seal, I broke down and bought the very pricy Porsche seal. In the end it was worth it-it only took me 15 minutes to install! ^ Hopefully, it will last longer than mine has, and allow your doors to close correctly? Maybe mine was from a bad batch, but 15 minutes sounds about right. As far as lasting, I'm now going two years on a daily driver and it still looks great. I had no trouble with the doors closing correctly. |
Lo-Fi Version | Time is now: 26th May 2024 - 11:46 AM |
