Need help with my glove box lock position, Need help with my glove box lock position |
SFGreg |
Apr 3 2021, 11:27 PM
Newbie Group: Members Posts: 9 Joined: 15-November 19 From: Point Richmond CA Member No.: 23,643 Region Association: Northern California |
I could use some help diagnosing my glove box locking problem. I acquired my ’74 2 years ago and have just got around to seeing why the glove box door won’t lock. If I had a correct 914 dash to compare, the issue would be obvious, but I don’t!
Here are my observations – photos attached: The glove box lock mechanism operates fine. The Lock TAB that is supposed to rotate so as to block the door doesn’t reach any effective position. Too short (why?) Wrong rotational position? Tilted? Is the lock mechanism-mounting hole deformed? Is a part of my box door missing? Key position at 1030 the tab is at 430 but is not enough behind the door. Key position at 130 the tab is at 730. Yes, looks like a previous owner cut up the dash radio hole to fit a newer stereo. Thanks for any help! Cheers Greg |
FL000 |
Apr 4 2021, 09:29 AM
Member Group: Members Posts: 397 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I don’t have any pics handy and can’t see squat on mine. 73, and I did confirm that 130 is unlocked and 1030 is locked. Also confirmed that the door has to be almost fully closed to lock it, otherwise the mechanism behind the door interferes. I am others will chime in. Good luck.
SFGreg |
Apr 4 2021, 10:02 AM
Thanks for checking for me. That helps. I had thought maybe the whole lock was rotated but it does seem to seat in a notched position at 1030/130.
Shivers |
Apr 4 2021, 10:04 AM
Senior Member Group: Members Posts: 2,400 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I went out to mine and the gb door has a tab that protrudes towards the lock. That's why the arm from the lock looks so short, it doesn't need to reach the door, the door reaches it.
Morph914 |
Apr 4 2021, 12:24 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Maybe these can help, I took these before and during the disassembly.
Cheers, John |
SFGreg |
Apr 4 2021, 02:18 PM
Nice photos, thanks. The picture is getting clearer. My lock must be okay.
Your last photo corroborates my gb door must have something missing that reaches toward the lock tab. I'll search for a photo on line. |
SFGreg |
Apr 4 2021, 02:33 PM
Found a good photo.
It appears that the metal flange for the spring attachment is also used for the locking of the door. I'm not at my car now, but dollars to donuts mine is missing or severly bent on the left side. Problem solved. Y'all rock. Attached image(s) |
Lo-Fi Version | Time is now: 27th May 2024 - 10:40 AM |
