I could use some help diagnosing my glove box locking problem. I acquired my ’74 2 years ago and have just got around to seeing why the glove box door won’t lock. If I had a correct 914 dash to compare, the issue would be obvious, but I don’t!
Here are my observations – photos attached:
The glove box lock mechanism operates fine.
The Lock TAB that is supposed to rotate so as to block the door doesn’t reach any effective position.
Too short (why?)
Wrong rotational position? Tilted?
Is the lock mechanism-mounting hole deformed?
Is a part of my box door missing?
Key position at 1030 the tab is at 430 but is not enough behind the door.
Key position at 130 the tab is at 730.
Yes, looks like a previous owner cut up the dash radio hole to fit a newer stereo.
Thanks for any help!
Cheers
Greg
