Vacuum Hose changes, 75/76 Air cleaner and oil filler changed now where connect? |
Wew |
Apr 5 2021, 09:59 AM
Member Group: Members Posts: 227 Joined: 17-January 15 From: Novato, ca Member No.: 18,335 Region Association: None |
Hi all,
Have been working on my engine and transmission rebuilds. Almost there. Question is I had new heads machined and now notice there are no vacuum ports on the heads like my old ones. I borrowed this schematic from another member and added the thin red line, circle and arrow to the drawing to show what I am talking about. Do I just remove that piece and plug the hole on the air cleaner? Do I reroute some lines? Anyone who has been down this road I appreciate you input. Thanks, Gary |
rjames |
Apr 5 2021, 10:25 AM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Get rid of the T fitting and route the hose from the air box to the port on the oil filler.
JamesM |
Apr 8 2021, 12:56 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Get rid of the T fitting and route the hose from the air box it to the port on the oil filler. Also need to replace the PCV on the oil filter with an open port. Ideally you would want to replace the oil filler and air filter housing with the later style ones with a larger port as the single 13mm hose doesent provice adiquate venting without the heads ports. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:20 AM |
