ultrasonic cooler cleaning, Yo Cap'n Krusty - need data ! |
ArtechnikA |
Jul 20 2005, 12:23 PM
John - somewhere (can't find it now...) you offered to broker oil cooler cleaning.
i need it. one soonish, couple more later. i have your address; pls advise cost & lead time for an early (screw fitting) 911 cooler. i figure return shipping will be about the same as what it costs to get there, so i can add that on my end. might be an idea to mention this service in the "Resources" section... thanks! |
Gint |
Jul 22 2005, 08:51 AM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
What ever happened here anyway? John? I'm in the same boat. |
ArtechnikA |
Jul 28 2005, 06:33 AM
here's some data from the 356 List the last time the question came up there:
Lanfried(Ultrasonic Cleaning) in Carson, CA: contact is Jerry Marquez at (310)327-8930; Pacific Oil Cooler at 800.866.7335; and Jim @ EASY has a Bay Area source since they're all in California and equally far from me, and since EASY has been a consistent and enthuiastic supporter of the 356 contingent, i expect that's where i'll be sending mine... |
MJHanna |
Jul 28 2005, 06:47 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
I have used Pacific
http://www.oilcoolers.com/ this is how they do it. http://www.oilcoolers.com/howwell.htm As they deal with aircraft coolers I went with them and was very happy with the service and results. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
ArtechnikA |
Jul 28 2005, 06:54 AM
interestingly, none of those 27 cleaning and flushing steps involves anything ultrasonic ... |
MJHanna |
Jul 28 2005, 07:01 AM
MORE THAN JUST A "FLUSH"
At Pacific Oil Cooler Service, Inc., the term "Overhaul" refers to our approved Process for Re-Certification of your oil cooler (or fuel heater, valve, condenser, evaporator, or intercooler). A good portion of this process is devoted to contaminant removal which begins with the use of our exclusive, state-of-the-art ultra-sonic cleaning equipment - and is followed up with a three step series of high-pressure and high-volume flushing operations. The required result is 100% contaminant removal from your part - no matter how 'plugged up' it may have been when we received it. Umm me thinks they use them all the time. Call them and ask. I did (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
MJHanna |
Jul 28 2005, 07:08 AM
I was very concerned about contamination when I sent them the cooler. I knew the eng used before with this cooler had been puked. I've had no issues with the cooler for the last 3 years. Just a satified customer...... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
ArtechnikA |
did you ask why it's not on the list of stuff they do :-) ? the 356 guys are coming out strongly in favor of Lanfried in Carson, FWIW. and since we don't know that EASY's mystery source isn't onw of those two, i'm thinking the direct approach may indeed be best... can i ask what it cost you, and for what kind of cooler? reports for Lanfried are in the $40-50 range for a 4-cyl sized cooler. |
DougC |
Jul 28 2005, 08:00 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
When they are just flushed what is the process compared to an ultrasonic cleaning? I mean why would you ever flush as opposed to cleaning? Would any airport have facilities to clean aircraft oil coolers? Seems like they would.
Doug C |
MJHanna |
Jul 28 2005, 11:31 AM
If I remeber correctly it was around $90 but it was a large cooler (see the front of the chassis) Its the Black area on the photo
Lo-Fi Version | Time is now: 16th May 2024 - 10:22 AM |
