Flywheel / crank end play, Did I do something wrong? |
adolimpio |
Apr 7 2021, 05:10 PM
Art Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
I finished building my engine, which uses a 2.0 crank in a 1.7 case.
My crank end play is 0.0125 without any shims. I've seen that you should use a minimum of 3 shims, but even a single smallest shim puts me at the edge of spec - 0.0125 - .00945 = 0.003. Is this OK? Did I do something wrong assembling? |
iankarr |
Apr 8 2021, 09:02 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The shims are available in a range of sizes. You'll need to calculate which thicknesses are needed to arrive a total end play of .003 - .005. Remember this is expressed in thousandths of an inch. It's confusing because the shims are sold by the dimension in mm. It's best to order a variety so you have them on hand when you're sorting it all out. You can always return the unused ones. They're not expensive regardless.
02loftsmoor |
Apr 8 2021, 09:19 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
The shims are available in a range of sizes. You'll need to calculate which thicknesses are needed to arrive a total end play of .003 - .005. Remember this is expressed in thousandths of an inch. It's confusing because the shims are sold by the dimension in mm. It's best to order a variety so you have them on hand when you're sorting it all out. You can always return the unused ones. They're not expensive regardless. where do get cheap shims? i saw some for $34 ,, $8 seems he going rate |
Lo-Fi Version | Time is now: 27th May 2024 - 06:40 PM |
