Flywheel / crank end play, Did I do something wrong? |
adolimpio |
Apr 7 2021, 05:10 PM
Art Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
I finished building my engine, which uses a 2.0 crank in a 1.7 case.
My crank end play is 0.0125 without any shims. I've seen that you should use a minimum of 3 shims, but even a single smallest shim puts me at the edge of spec - 0.0125 - .00945 = 0.003. Is this OK? Did I do something wrong assembling? |
02loftsmoor |
Apr 8 2021, 08:47 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
I'm replacing the Flywheel .
i have Three .010" shims in, and i have .012" end play. what do i need to change?? |
Mark Henry |
Apr 9 2021, 09:56 AM
02loftsmoor |
Apr 9 2021, 06:59 PM
I'm replacing the Flywheel . i have Three .010" shims in, and i have .012" end play. what do i need to change?? So you need .038" worth of shims to get .004" end play, a combo of shims like .012" + .012" + .014" = .038" will work. thank you for the tip!! shims on order |
Lo-Fi Version | Time is now: 27th May 2024 - 02:42 PM |
