Flywheel / crank end play, Did I do something wrong? |
adolimpio |
Apr 7 2021, 05:10 PM
Art Group: Members Posts: 180 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
I finished building my engine, which uses a 2.0 crank in a 1.7 case.
My crank end play is 0.0125 without any shims. I've seen that you should use a minimum of 3 shims, but even a single smallest shim puts me at the edge of spec - 0.0125 - .00945 = 0.003. Is this OK? Did I do something wrong assembling? |
Mark Henry |
Apr 10 2021, 06:13 AM
When you get the shims be sure to test fit first. You must be sure that your measuring and my maths are correct.
(IMG:style_emoticons/default/smile.gif) |
02loftsmoor |
Apr 11 2021, 08:18 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
When you get the shims be sure to test fit first. You must be sure that your measuring and my maths are correct. (IMG:style_emoticons/default/smile.gif) will do, I had a hard time wrapping my head a round this, thanks every one for the help .. |
Lo-Fi Version | Time is now: 6th May 2024 - 07:36 AM |
