> Emergency brake, No resistance on lever, does not engage
tsvo
post Apr 7 2021, 06:22 PM
Hello, my emergency brake no longer has any resistance on the lever when you pull on it. It does not lock or engage the brake. Where do I start to find the issue?
Regards,
Terry
Dave_Darling
post Apr 7 2021, 06:45 PM
914 Idiot
Check to see if the cables are still attached to the arms on the rear brake calipers.
--DD
tsvo
post Apr 7 2021, 06:51 PM
QUOTE(Dave_Darling @ Apr 7 2021, 07:45 PM) *
--DD
Thank you Dave. I will start there.
pcdarks
post Apr 7 2021, 07:02 PM
You have a single cable about 8 inches long that then splits and pulls left and right. This is located under the drivers seat and is easily accessible once the seat is out. there is a plate covering it with two small screws.The other ends go directly to the rear calipers.
tsvo
post Apr 7 2021, 07:11 PM
QUOTE(pcdarks @ Apr 7 2021, 08:02 PM) *
Thank you for the details. I will give it a look.
Olympic 914
post Apr 8 2021, 05:51 PM
May also need to set the air gap on the pads.
.004
If its too large your parking brake won't work.
tsvo
post Apr 8 2021, 06:26 PM
QUOTE(Olympic 914 @ Apr 8 2021, 06:51 PM) *
.004
Thank you, I will check that as well.
One more question, besides the brake cable wire, what is the second wire under the driver's seat?
tsvo
post Apr 8 2021, 06:27 PM
tsvo
--DD
bdstone914
post Apr 8 2021, 06:43 PM
bdstone914
QUOTE(tsvo @ Apr 8 2021, 05:27 PM) *
--DD
The cable runs from the end of rhe handle the the equalizer at the firewall. Skider the seat forward and see if it is intact
Spoke
post Apr 8 2021, 06:58 PM
Jerry
Did the ebrake ever work or is this a new issue?
tsvo
post Apr 8 2021, 07:08 PM
QUOTE(Spoke @ Apr 8 2021, 07:58 PM) *
I removed the seat. The cable from the brake looked good. I wiggled it around a little and the brake works fine. Kind of concerns me so ce I didn't really do anything.
While under there I found this second wire, what is it? Fasten seat belt sensor? It wasn't attached to anything. It was just kind of stuck in the hole on the floor near the base of the brake. Perhaps it was interfering?
bbrock
post Apr 8 2021, 07:51 PM
QUOTE(tsvo @ Apr 8 2021, 06:08 PM) *
Maybe the wire to the brake light switch? Is it brown?
tsvo
post Apr 8 2021, 08:04 PM
QUOTE(bbrock @ Apr 8 2021, 08:51 PM) *
Yes, it is brown.
bbrock
post Apr 8 2021, 09:54 PM
QUOTE(tsvo @ Apr 8 2021, 07:04 PM) *
Yes, it is brown.
Sounds like the wire that should run to the contact switch that the e-brake handle pushes down and rests on when it is off.
Dion
post Apr 9 2021, 04:41 AM
RN
Visual aide
tsvo
post Apr 9 2021, 05:25 AM
QUOTE(Dion @ Apr 9 2021, 05:41 AM) *
Visual aide
That is absolutely it. Mine is not connected. Seems to be broken. What issue will this create?
ClayPerrine
post Apr 9 2021, 05:55 AM
QUOTE(tsvo @ Apr 9 2021, 06:25 AM) *
There is a big red light in the left hand gauge that is supposed to flash when the park brake is engaged. That is the wire for it. It should go to a switch that gets depressed when you lower the handle.
It is the same basic switch as the door jam switches for the interior lights. They are inexpensive and can be picked up from your favorite parts pusher vendor.
tsvo
post Apr 9 2021, 06:11 AM
QUOTE(ClayPerrine @ Apr 9 2021, 06:55 AM) *
Thanks for the info. That is what it is. The light is now on, never was before. Where do you gain access to replace the switch?
BeatNavy
post Apr 9 2021, 06:30 AM
If you look in Dion's second pic above you can see the switch is mounted right into that metal cross member on the floor pan and then grounded to the chassis. Get a replacement switch and insert it into that square shaped hole on the metal cross member. Then make sure the wire is grounded either by connecting it what's left of the original wire or doing it in a manner similar to what Dion did.
Just to be clear, the e-brake is a mechanical setup, though. In and of itself this isn't causing the original issue you described (unless pieces of your switch are interfering with operation somehow).
- Lo-Fi Version Time is now: 30th June 2025 - 07:45 PM
