Decided on EZ Car Lift., Confirming configuration... |
FlacaProductions |
Apr 12 2021, 01:44 PM
Senior Member Group: Members Posts: 1,591 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done lots of reading here and I've decided that the EZ Car Lift is right for me. Thanks to all who have documented their lift setups.
Confirming that I should get the XMC59 crossbars and a set of 4 hockey pucks. Also leaning toward the Ridgid R5011 Drill, 1/2-Inch 2-Speed Hammer Drill as it's one of the highly recommended ones from the EZ Car Lift manufacturer. Anything I'm missing? Really looking forward to this - everybody raves about a lift....it's just finding the one that fits your situation. |
mepstein |
Apr 12 2021, 02:06 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I need to set anchors for my maxjax. I was told to rent a big drill rather than buying a consumer model. And get a good drill bit.
Lg914 |
Apr 12 2021, 02:32 PM
Member Group: Members Posts: 53 Joined: 4-July 19 From: Lake Geneva Member No.: 23,275 Region Association: None |
I need to set anchors for my maxjax. I was told to rent a big drill rather than buying a consumer model. And get a good drill bit. I think there may be a misunderstanding. I believe the ez car lift needs the power of a drill to operate. The drill turns a shaft that raises and lowers the lift. But then again I could be wrong. |
mepstein |
Apr 12 2021, 02:53 PM
I need to set anchors for my maxjax. I was told to rent a big drill rather than buying a consumer model. And get a good drill bit. I think there may be a misunderstanding. I believe the ez car lift needs the power of a drill to operate. The drill turns a shaft that raises and lowers the lift. But then again I could be wrong. I'm sure your right. |
VaccaRabite |
Apr 13 2021, 07:48 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I need to set anchors for my maxjax. I was told to rent a big drill rather than buying a consumer model. And get a good drill bit. I think there may be a misunderstanding. I believe the ez car lift needs the power of a drill to operate. The drill turns a shaft that raises and lowers the lift. But then again I could be wrong. I'm sure your right. But, yeah. Rent a "real" hammer drill and bits from Home Depot to set the anchors for the MaxJax. Money well spent seeing as how you will likely not use it again unless you start installing lifts. They are massive and powerful and will do the job quickly and more accurately then trying to fight with a consumer hammer drill that will stop in its tracks whenever you come across rebar or a stone in the concrete. Zach |
Lo-Fi Version | Time is now: 21st May 2024 - 09:57 AM |
