wtb: need a few misc parts, do you have 'em? |
iankarr |
Apr 13 2021, 10:17 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Here are a few things I need to progress in my build.
– Shifter front rod (the short one which goes from the gear shift to the firewall. (my car is a '74). – "intermediate" pieces for side air vents (the little curved ducts that feed the vents) x 2 – Door hinge pins x 2 – Right side tail light housing reflector – Rubber air sealing ring for alternator – E brake switch (the one the e brake handle rests on) Please lmk if you gots! Ian |
914werke |
Apr 13 2021, 10:23 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/idea.gif) ....
1. F. shift rod 2. Fresh air elbows 3. you took you dr. hinges apart ? or are you after the dr. stay pins 4. reflector, the clear corner insert? 5. Early ring 6. Park brake switch (edited) (IMG:style_emoticons/default/bye1.gif) |
Jett |
Apr 13 2021, 10:44 PM
Senior Member Group: Members Posts: 1,636 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/idea.gif) .... 1. F. shift rod 2. Fresh air elbows 3. you took you dr. hinges apart ? or are you after the dr. stay pins 4. reflector, the clear corner insert? 5. n/a 6. Park brake switch (IMG:style_emoticons/default/bye1.gif) I think 914 Rubber have #5 |
carl k |
Apr 15 2021, 08:46 AM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
@iankarr
"– Rubber air sealing ring for alternator" Are you referring to the plastic ring that goes between the alternator and the cooling tin? If so, which shape tin do you have- the one with the round cutout or the oval? -Carl |
iankarr |
Apr 16 2021, 10:36 AM
Thanks @carl k . Yes, I guess it is plastic. Looks to be like it might be the upper left one in your photo.
My tin is round. Here's a pic... |
carl k |
Apr 17 2021, 04:03 PM
@iankarr- I have this one, I'll send you a PM. thanks! Carl |
Lo-Fi Version | Time is now: 28th April 2024 - 04:57 PM |
