Fuel vapor venting, 914-6 part |
Dion |
Apr 14 2021, 11:35 AM
RN Group: Members Posts: 2,766 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
So, I don’t have a charcoal canister. I’ve eliminated the lines and holders that are in the left long area. I was hoping to mimic the 914-6 set up as I’m installing a six.
I was wondering if anyone knows the name of the plastic piece that joins the expansion tank with the fuel overflow tube. I have a pic pulled off the net but no official name for it. What are the odds of getting one on a WTB add? If anyone has an idea on one or something similar, be cool. Attached image(s) |
SirAndy |
Apr 14 2021, 12:00 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I’ve eliminated the lines and holders that are in the left long area. I was hoping to mimic the 914-6 set up as I’m installing a six. Probably the worst decision i've ever made when i did my car. (IMG:style_emoticons/default/icon8.gif) The overflow drain works but without the charcoal canister, you will get nauseating fuel vapors inside the cabin every time you take a spirited turn with 3/4+ gas in the tank. (IMG:style_emoticons/default/barf.gif) When i'm done with my real /6 it'll have a fully functional charcoal canister setup. (IMG:style_emoticons/default/shades.gif) |
Dion |
Apr 14 2021, 12:22 PM
@SirAndy hmmmm ok. I’ll see what I can muster up then with regards to venting. Have it go to a charcoal canister then I guess I can direct it down & out. Let me have a think on this. Thanks
Steve |
Apr 14 2021, 01:21 PM
914 Guru Group: Members Posts: 5,596 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
On my 3.2 conversion, i installed a 75 charcoal canister in front of the battery where the 4 banger computer goes. This way I only had to run one line from the tank to the engine compartment. No vapors in the garage or the car.
ClayPerrine |
Apr 14 2021, 02:11 PM
Life's been good to me so far..... Group: Admin Posts: 15,483 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I just finished up the process of installing all the plastic lines in the left long for the canister. I will hook it up like the 964 canister purge setup.
The canister and associated lines are negligible in weight, and make the car much nicer... no gas smell. And it is better for the environment. I will be putting them back on the factory six after I finish this one. Clay |
Lo-Fi Version | Time is now: 26th May 2024 - 02:35 AM |
