Help requested for locating a UEGO, on a Dansk Muffler |
rbzymek |
Apr 14 2021, 02:49 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
I need to have a UEGO bung welded on my Dansk banana muffler. Can someone advise a good location clear of any baffling or packing materials? Thanks in advance. Ray
infraredcalvin |
Apr 14 2021, 03:43 PM
Distracted Member Group: Members Posts: 1,510 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Pics would help, but that's a 2 in one out muffler? You should have 2 one at each inlet to the muffler (or better yet) on the ends of the heat exchangers nearest the muffler. If it's dual pipes going into each inlet then I personally don't think there is a good answer besides putting one on each - that's an overkill. I'd be concerned that you'll get too much fresh air contamination putting near the muffler outlet, and not enough mixture data putting it near the inlets.
rbzymek |
Apr 14 2021, 04:04 PM
It’s a four in one out set up with 2.0 HE’s. It is L-Jet so all cylinders get very close to the same amount of fuel. That makes mixing a smaller issue. I just don’t want to interfere with internal structures. Thanks for your input.
Lo-Fi Version | Time is now: 3rd May 2024 - 01:25 PM |
