1973 2.0 Voltage Regulator, I'm looking for a 1973 2.0 Voltage Regulator, NOS or good replacemen part |
9ONE4_JIM |
Apr 14 2021, 05:12 PM
Newbie Group: Members Posts: 4 Joined: 18-February 21 From: Solvang, CA Member No.: 25,221 Region Association: Central California |
johnhora |
Apr 14 2021, 05:48 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
what problems are you having that makes you think it's bad
I have used ones if needed... |
9ONE4_JIM |
Apr 14 2021, 05:58 PM
I have used ones if needed... I just acquired this car and am in the process of "Dialing-It-In." During a 40 mile trip back home from my mechanic (my first night drive in this car) I noticed that the dash lights were modulating from dim to brighter about halfway into the trip. I then noticed that my headlight were doing the same thing. During a call to the mechanic the next day he stated that the culprit is the voltage regulator. In that he has been working on these cars since 1974 I took his assessment seriously. Your thoughts... |
914Sixer |
Apr 14 2021, 08:27 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The ones from 914 Rubber are exact fit. Only thing is you need a larger washer because they have a larger hole.
bdstone914 |
Apr 14 2021, 09:14 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
what problems are you having that makes you think it's bad I have used ones if needed... I just acquired this car and am in the process of "Dialing-It-In." During a 40 mile trip back home from my mechanic (my first night drive in this car) I noticed that the dash lights were modulating from dim to brighter about halfway into the trip. I then noticed that my headlight were doing the same thing. During a call to the mechanic the next day he stated that the culprit is the voltage regulator. In that he has been working on these cars since 1974 I took his assessment seriously. Your thoughts... Sounds more like a light switch problem. Check the voltage across the battery terminals with the engine running and not running. It should be higher when running. You might need a new mechanic too. |
9ONE4_JIM |
Apr 14 2021, 10:59 PM
You might need a new mechanic too. LOL. Well I guess I better get the mechanic tested as well. Thanks for your input; I'll test via the terminals. |
Warren914 |
Apr 15 2021, 09:00 AM
Member Group: Members Posts: 93 Joined: 26-February 21 From: Nova Scotia Member No.: 25,265 Region Association: Canada |
I replaced the original mechanical regulator with a solid state Wells VR650. Case is a little different but it fits fine. Looks like Duralast is the same part. https://www.autozone.com/batteries-starting...-vr650/2840_0_0 |
Lo-Fi Version | Time is now: 29th April 2024 - 10:29 AM |
