Horn Blows Without Fuse |
pfreiburger |
Apr 14 2021, 05:31 PM
Member Group: Members Posts: 109 Joined: 6-October 20 From: Fond du Lac, WI Member No.: 24,738 Region Association: None |
My horn blows when the wheel is turned regardless of what fuse is pulled - I tried them all. ideas?
johnhora |
Apr 14 2021, 05:54 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
it's possibly wired directly to 12v hot lead
Root_Werks |
Apr 15 2021, 08:51 AM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
it's possibly wired directly to 12v hot lead (IMG:style_emoticons/default/agree.gif) The horn Positive supply should go through the fuse panel. Check the fuse panel, could be someone plugged the wire into the wrong side of the correct slot or another slot. |
pfreiburger |
Apr 15 2021, 08:58 AM
it's possibly wired directly to 12v hot lead (IMG:style_emoticons/default/agree.gif) The horn Positive supply should go through the fuse panel. Check the fuse panel, could be someone plugged the wire into the wrong side of the correct slot or another slot. Thanks much for the reply, I will drop the fuse box and check that next. I see that there is a dedicated horn relay as well. I have a wiring diagram on the way, so I will be able to pull the relay and check out the circuits. |
Root_Werks |
Apr 15 2021, 09:30 AM
it's possibly wired directly to 12v hot lead (IMG:style_emoticons/default/agree.gif) The horn Positive supply should go through the fuse panel. Check the fuse panel, could be someone plugged the wire into the wrong side of the correct slot or another slot. Thanks much for the reply, I will drop the fuse box and check that next. I see that there is a dedicated horn relay as well. I have a wiring diagram on the way, so I will be able to pull the relay and check out the circuits. Good idea on the relay, could be bad? Shorted? |
pfreiburger |
Apr 15 2021, 10:38 AM
it's possibly wired directly to 12v hot lead (IMG:style_emoticons/default/agree.gif) The horn Positive supply should go through the fuse panel. Check the fuse panel, could be someone plugged the wire into the wrong side of the correct slot or another slot. Thanks much for the reply, I will drop the fuse box and check that next. I see that there is a dedicated horn relay as well. I have a wiring diagram on the way, so I will be able to pull the relay and check out the circuits. Good idea on the relay, could be bad? Shorted? Could be. New ones are inexpensive and considering the age, I might just replace all 3 at the same time, regardless of whatever else I find. |
Lo-Fi Version | Time is now: 26th April 2024 - 03:01 PM |
