Battery Box's for Front Trunk Location, Battery Box's |
NS914 |
Apr 16 2021, 10:33 AM
Member Group: Members Posts: 198 Joined: 9-June 09 From: Dartmouth, Nova Scotia Member No.: 10,455 Region Association: Canada |
Hi Everyone,
I am just replumbing my supply lines to the Master Cylinder and re installing my fuel tank. One thing I need to start thinking about is my Battery Mount and possibly Box type to secure it. I have located my fuel pump in the trunk as well. Could I see some Battery Boxes and how you have secured them? I am have a new Red Top Optima Battery for the car from a size point of view etc. Much thanks, Grant |
914Toy |
Apr 16 2021, 10:49 AM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
Hi Everyone, I am just replumbing my supply lines to the Master Cylinder and re installing my fuel tank. One thing I need to start thinking about is my Battery Mount and possibly Box type to secure it. I have located my fuel pump in the trunk as well. Could I see some Battery Boxes and how you have secured them? I am have a new Red Top Optima Battery for the car from a size point of view etc. Much thanks, Grant Keep it simple - non leak battery, battery footprint platform of aluminum, metal strap to wheel well. |
Apr 16 2021, 11:12 AM
I would keep it in the stock location. Won’t need long cables. Won’t take up room in the trunk, helps balance out driver weight, etc. no downside if it’s a sealed battery.
Mark Henry |
Apr 16 2021, 02:25 PM
If you do this make sure you use heavy duty grommets every point the cable passes through metal.
That battery has enough juice to burn your teen to the ground. |
NS914 |
Aug 16 2023, 12:48 PM
I hadn't thought about a simple metal strap. I had been mostly focused on bolting it to the floor and using some form of rubber to isolate from jumping around in frunk.
Mark's comments re Grommets...absolutely! I have been inserting Grommets everywhere but truly thank you for reinforcing a good idea. [/quote] |
NS914 |
apologies double post, when I figure out how to delete I will do that.
Lo-Fi Version | Time is now: 17th May 2024 - 05:18 PM |
