914-4 crossmember FS, freshly powdercoated |
Speedo |
Apr 22 2021, 06:13 PM
Senior Member Group: Members Posts: 529 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains |
I had this sandblasted and powdercoated a few years ago for my 6...not realizing that it was for a 4. It is in really nice shape, ready to bolt up. I had to source, sandblast and now powdercoat the correct 6 crossmember. My powdercoating is going to cost me north of $120. Asking $100 obo for this guy plus shipping.
pilothyer |
Apr 23 2021, 10:51 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
PET Shows that the 914-4 and 914-6 shares the same number for that part. Auxiliary Support 90134101303 Even the early 911 except for the end number 901341013(02) which was because it was aluminum. Can you see any difference between the two you have.................just curious I guess (IMG:style_emoticons/default/smile.gif) I remember when the "hot set-up" was to get the same part 90134101302 off of the early 911 and since it was aluminum you could shave a few pounds of weight. It bolted right in but there were no holes to bolt on the protective cover plate at the front.
http://www.914world.com/bbs2/index.php?sho...y++support++911 |
bdstone914 |
Apr 25 2021, 07:38 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
PET Shows that the 914-4 and 914-6 shares the same number for that part. Auxiliary Support 90134101303 Even the early 911 except for the end number 901341013(02) which was because it was aluminum. Can you see any difference between the two you have.................just curious I guess (IMG:style_emoticons/default/smile.gif) I remember when the "hot set-up" was to get the same part 90134101302 off of the early 911 and since it was aluminum you could shave a few pounds of weight. It bolted right in but there were no holes to bolt on the protective cover plate at the front. http://www.914world.com/bbs2/index.php?sho...y++support++911 The 911 and i assume the 914-6 have a square end unlike the one pictured. There are several parts i know of that have non functional differences and share the same part number. The upper strut bearings are another example. The housing in the 911 are shorter. @pilothyer |
Lo-Fi Version | Time is now: 19th May 2024 - 06:58 AM |
