Subi Transmission Help needed.. |
Literati914 |
Apr 23 2021, 02:06 PM
Senior Member Group: Members Posts: 1,461 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Hey guys, been keepin' my eyes peeled for a transmission to mate to the EG33 flat six subaru engine that I'll be using, and just located the following -
from description: "2015+ WRX transmission etc" He'll sell me the trans for $400, but he also has stock Subi cable shifter set up, axles, starter and what looks like an ECU (trans ecu??). Should I try to snag anything besides just the transmission? . |
Apr 23 2021, 02:32 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would grab everything if it’s cheap.
You want the starter and the conversion axles use a Suby cv at the trans stubs so grab the axles for the cv’s. |
Literati914 |
Apr 23 2021, 03:53 PM
.. good, I'll look to get the starter and output CVs..
So, the ECU looking thing's not gonna be needed then? Just don't want to pay extra for something I wouldn't need. Thx. OH - and the cable shifter stuff? will those stock items transfer for 914 conversion? . |
Apr 23 2021, 04:29 PM
I am using the stock engine ecu on my eg33 conversion.
tazz9924 |
Apr 23 2021, 06:06 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Literati914 |
Apr 23 2021, 07:20 PM
.. Will it work? are those motors still ej? usually we use early 2000 transmissions OOh.. I never heard of needing to use a transmission from any particular years (w/ the EG33), or from a particular engine type. ANYONE KNOW about this before I make a big mistake (IMG:style_emoticons/default/headbang.gif) . |
76-914 |
Apr 23 2021, 09:02 PM
Hey guys, been keepin' my eyes peeled for a transmission to mate to the EG33 flat six subaru engine that I'll be using, and just located the following - from description: "2015+ WRX transmission etc" He'll sell me the trans for $400, but he also has stock Subi cable shifter set up, axles, starter and what looks like an ECU (trans ecu??). Should I try to snag anything besides just the transmission? . 2003+ transmissions became beefier. You won't be able to use the stock Subi shifter set up. The TY754 series transmission don't use an ECU. You will need an ECU from any SVX. |
Literati914 |
Apr 23 2021, 10:35 PM
.. 2003+ transmissions became beefier. You won't be able to use the stock Subi shifter set up. The TY754 series transmission don't use an ECU. You will need an ECU from any SVX. OK. Beefier but will still work I suppose? Won't bother with the shifter stuff - thanks. I'll probably be using an after market FI system, I just don't know if the pictured ecu-looking item is transmission specific/necessary or an actual engine ecu. The guy selling this stuff tells me he removed these pieces for an out-of-town customer and installed an STi transmission for him (in his regular WRX). . |
mgp4591 |
Apr 23 2021, 10:55 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
.. 2003+ transmissions became beefier. You won't be able to use the stock Subi shifter set up. The TY754 series transmission don't use an ECU. You will need an ECU from any SVX. OK. Beefier but will still work I suppose? Won't bother with the shifter stuff - thanks. I'll probably be using an after market FI system, I just don't know if the pictured ecu-looking item is transmission specific/necessary or an actual engine ecu. The guy selling this stuff tells me he removed these pieces for an out-of-town customer and installed an STi transmission for him (in his regular WRX). |
mgp4591 |
Apr 23 2021, 10:58 PM
.. 2003+ transmissions became beefier. You won't be able to use the stock Subi shifter set up. The TY754 series transmission don't use an ECU. You will need an ECU from any SVX. OK. Beefier but will still work I suppose? Won't bother with the shifter stuff - thanks. I'll probably be using an after market FI system, I just don't know if the pictured ecu-looking item is transmission specific/necessary or an actual engine ecu. The guy selling this stuff tells me he removed these pieces for an out-of-town customer and installed an STi transmission for him (in his regular WRX). The ECU won't work...you need a complete aftermarket system or the stock SVX ECU. Axles will work for your axle conversion. I don't know anyone who's using a transmission from something that new... if he's local, take your needed bolt measurements for the trans and line them up with where that trans has them located. Also, is it a 6spd trans? If it is, you'll probably end up losing your trunk because they're bigger in about every respect. |
808 WRX |
Apr 23 2021, 10:59 PM
Member Group: Members Posts: 59 Joined: 4-June 20 From: San Jose, CA Member No.: 24,349 Region Association: Northern California |
I'll probably be using an after market FI system, I just don't know if the pictured ecu-looking item is transmission specific/necessary or an actual engine ecu. The guy selling this stuff tells me he removed these pieces for an out-of-town customer and installed an STi transmission for him (in his regular WRX). The subaru manual transmissions do not use a ECU/computer of any sort. The 2015+ subaru transmissions with cable shifters are 6-speeds right? Has anyone put one into a 914? Do the 2WD conversion couplers work in the newer 6-speed transmissions? |
Literati914 |
Apr 23 2021, 11:05 PM
.. here's a pic, click it an then expand it, if interested. Thanks for all the help guys!
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.postimg.cc-7222-1619241005.1.jpg) |
mgp4591 |
Apr 23 2021, 11:11 PM
If you've got the patience and it's all available for only 400 bucks, you might want to pick it up and resell it...make some extra cash for your 914 project! (IMG:style_emoticons/default/biggrin.gif) |
Literati914 |
Apr 23 2021, 11:17 PM
If you've got the patience and it's all available for only 400 bucks, you might want to pick it up and resell it...make some extra cash for your 914 project! (IMG:style_emoticons/default/biggrin.gif) No, he's only willing to let go of the tranny itself for the $400, which is why I'm trying to figure out what if anything else, might come in handy. I'll drop a little more if need be. |
808 WRX |
Apr 24 2021, 12:27 AM
Literati914 |
Apr 24 2021, 12:51 AM
Thanks.. in that thread @914subaru wrote (post #4): "..I haven't driven a 6-speed yet but my thought is if you already have a 5-speed it's not worth the upgrade but if your just starting a project it's worth considering. One advantage is the cable linkage is built into the transmission and you can use the Subaru shift lever." Hopefully 914suburu will check in here & confirm... but it sounds from the above statement that I should snag the shifter stuff too. confused as usual (IMG:style_emoticons/default/blink.gif) . |
mgp4591 |
Apr 24 2021, 01:41 AM
Thanks.. in that thread @914subaru wrote (post #4): "..I haven't driven a 6-speed yet but my thought is if you already have a 5-speed it's not worth the upgrade but if your just starting a project it's worth considering. One advantage is the cable linkage is built into the transmission and you can use the Subaru shift lever." Hopefully 914suburu will check in here & confirm... but it sounds from the above statement that I should snag the shifter stuff too. confused as usual (IMG:style_emoticons/default/blink.gif) . Okay! Then grab the trans, the shifter, and the axles...that's a pretty good deal I'd say! |
mgp4591 |
Apr 24 2021, 01:42 AM
Thanks.. in that thread @914subaru wrote (post #4): "..I haven't driven a 6-speed yet but my thought is if you already have a 5-speed it's not worth the upgrade but if your just starting a project it's worth considering. One advantage is the cable linkage is built into the transmission and you can use the Subaru shift lever." Hopefully 914suburu will check in here & confirm... but it sounds from the above statement that I should snag the shifter stuff too. confused as usual (IMG:style_emoticons/default/blink.gif) . Okay! Then grab the trans, the shifter, and the axles...that's a pretty good deal I'd say! Oh, and the starter too... |
Literati914 |
Apr 24 2021, 10:08 AM
..Okay! Then grab the trans, the shifter, and the axles...that's a pretty good deal I'd say! ..oh, and the starter too... Looks like maybe a separate master cylinder is there too.. I haven't got as far as researching what clutch set up to use... do I need it? . |
76-914 |
Apr 24 2021, 10:38 AM
Ross tol me that there are 2 different 6 speed transmissions. The one he is using is the same length as the 5 speed. That is all I know about this 2nd 6 speed transmission so far. Get the axles too since yours has the female output flanges. Besides, the OEM Subaru CV's are far superior to any Chinese aftermarket CV's. You can use either the Subaru or 914 half shafts and have one end machined at Dutchman's. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 02:07 PM |
