QUOTE(Literati914 @ Apr 23 2021, 11:51 PM)
Hopefully 914suburu will check in here & confirm... but it sounds from the above statement that I should snag the shifter stuff too. confused as usual
I haven't seen anyone who has installed a 6-speed yet. So there are lots of unknowns. But if you are going to try, you should get the front axles as 76-914 mentioned.
Chances are the cables won't be the correct length. The shifter in the subaru would be pretty close to the transmission while in a 914 it would be in front of the engine and halfway into the passenger compartment. You might be able to make the shifter work (with longer cables) if the cables enter the shifter from the rear. On the other hand, having the stock set up might help you figure out/design a new setup.
Also, there is a different starter that has the solenoid off to the side instead of on top, which gives you a little more room so you don't have to cut your trunk.
You do need the slave cylinder (the dark thing next to the master cylinder) but you'll have to decide between new vs. used. I don't think I have seen anyone using a subaru master cylinder.
The used transmission mount might be good for mocking things up if it is cheap.
